查看: 4898|回复: 3
用WORD调用CAD图
发表于 2002-4-14 22:20:00 | 显示全部楼层 |阅读模式
我现在要把CAD图在WORD中显示。不知如何实现,请各位高手指教。
发表于 2002-4-14 23:02:00 | 显示全部楼层
输出为WMF文件,在WORD导入就可以
发表于 2002-4-15 08:45:00 | 显示全部楼层
剪贴图面到WORD
;;;工作平台:AUTOCAD 2000以上
;;;功能:剪贴图面到WORD(背景白色)
;;;贴上word时请用"选择性贴上"→"图片"
;;;配合:XDRX_API15(晓东cad空间) 及 doslib6.0 BETA
;;;程序设计:赖云龙
(defun LRBT (PT1     PT2     /             HOLDECHO             HOLDBLIP
             HOLDOSMODE             ANG     DIST    H             W             CTR
             RT             LB             RB             LT
  (setq HOLDECHO (getvar "cmdecho"))
  (setq HOLDBLIP (getvar "blipmode"))
  (setq HOLDOSMODE (getvar "osmode"))
  (setvar "cmdecho" 0)
  (setvar "blipmode" 0)
  (setvar "osmode" 0)
  (setq ANG (angle PT1 PT2))
  (setq DIST (distance PT1 PT2))
  (setq H (abs (- (cadr PT1) (cadr PT2))))
  (setq W (abs (- (car PT1) (car PT2))))
  (setq CTR (polar PT1 ANG (/ DIST 2.0)))
  (setq        RT (list (+ (car CTR) (/ W 2))
                 (+ (cadr CTR) (/ H 2))
  (setq        LB (list (- (car CTR) (/ W 2))
                 (- (cadr CTR) (/ H 2))
  (setq        RB (list (+ (car CTR) (/ W 2))
  (setq        LT (list (- (car CTR) (/ W 2))
  (grdraw LB RB 3 1)
  (grdraw RB RT 3 1)
  (grdraw RT LT 3 1)
  (grdraw LT LB 3 1)
  (setvar "blipmode" HOLDBLIP)
  (setvar "cmdecho" HOLDECHO)
  (setvar "osmode" HOLDOSMODE)
(arxload "xdrx_api15" NIL)
(arxload "doslib2k" NIL)
(defun CLIP (FLAG         /             PT1         PT2
             HOLDVIEWPORT             HOLDCOLOR         ACADOBJECT
             PREF         PREF_DISPLAY
;;;截录:自明经信道
;;;十进制转换为其它进制
  (defun DECIMALTOBASE (BASE VAL / RESULT TMP)
    (setq RESULT "")
    (while (> VAL 0)
      (setq RESULT (strcat (if (> (setq TMP (rem VAL BASE)) 9)
                             (chr (+ TMP 55))
                             (itoa TMP)
                           RESULT
            VAL           (fix (/ VAL BASE))
    RESULT
;;;截录:明经信道
;;;其它进制转换为十进制
  (defun BASETODECIMAL (BASE VAL / POS POWER RESULT TMP)
    (setq POS         (1+ (strlen VAL))
          POWER         -1
          RESULT 0
          VAL         (strcase VAL)
    (while (> (setq POS (1- POS)) 0)
      (setq
        RESULT (+ RESULT
                  (* (if (> (setq TMP (ascii (substr VAL POS 1))) 64)
                       (- TMP 55)
                       (- TMP 48)
                     (expt BASE (setq POWER (1+ POWER)))
    RESULT
;;;命令:dwgblack
;;;将图中所有实体(包括块,嵌套块,尺寸中的无名块)都改变
;;;颜色、图层、线型。
;;;原作: XDsoft
;;;通用组码修改  cnum0  组码   cnum  组码值
  (defun DWGBLACK (PT1 PT2 / HOLDCLRD HOLDCLRT N1 LTLST SS KEY NUM NUM0 N E)
    (setq HOLDCLRD (getvar "dimclrd"))
    (setq HOLDCLRT (getvar "dimclrt"))
    (defun #CHG_DXF (E CNUM0 CNUM / TF BLKNA)
      (xdrx_setenttodb E)
      (setq TF (xdrx_getentdxf 0))
      (cond
        ((or
           (= TF "INSERT")
           (= TF "DIMENSION")
         (setq BLKNA (xdrx_getentdxf 2))
         (setq BLKNA (tblsearch "block" BLKNA))
         (setq E (cdr (assoc -2 BLKNA)))
         (while        E
           (xdrx_setenttodb E)
           (if (or
                 (= TF "INSERT")
                 (= TF "DIMENSION")
               (#CHG_DXF E CNUM0 CNUM)
               (xdrx_setenttodb E)
               (xdrx_modent CNUM0 CNUM)
           (setq E (entnext E))
        ((= TF "TOLERANCE")
         (setvar "dimclrd" CNUM)
         (setvar "dimclrt" CNUM)
         (command "_dim1" "update" E "")
        (t
    (defun GETLTP (NO / TF LYR LYRL)
      (setq TF t)
      (while (setq LYR (tblnext "ltype" TF))
        (setq LYRL (cons LYR LYRL))
        (setq TF NIL)
      (mapcar '(lambda (X) (cdr (assoc NO X))) (reverse LYRL))
    (xdrx_begin)
    (setq SS (ssget "C" PT1 PT2))
    (setq N        0
          N1        0
          LTLST        (GETLTP 2)
    (initget "1 2 3")
    (setq KEY (getstring "\n<1>改颜色/<2>改层/<3>改线型<原样>: "))
    (cond
      ((= KEY "1")
       (setq NUM (acad_colordlg 7))
       (setq NUM0 62)
      ((= KEY "2")
       (setq NUM (getstring "\n图层名称: "))
       (setq NUM0 8)
      ((= KEY "3")
       (if (< (length LTLST)
              9
           (princ "\n[")
           (repeat (length LTLST)
             (princ (strcat (rtos N1 2 0)
                            (nth N1 LTLST)
                            (if        (< N1
                                   (1- (length LTLST))
             (setq N1 (1+ N1))
           (princ "]<0>")
       (setq NUM (getstring "\n线型名称<continuous>: "))
       (cond ((= NUM NIL)
              (setq NUM "continuous")
             ((<= (ascii NUM) 57)
              (setq NUM (nth (read NUM) LTLST))
             (t)
       (setq NUM0 6)
    (if        (/= KEY "")
        (xdrx_setsstodb SS 0)
        (xdrx_pbarbegin "已经完成:" (sslength SS))
        (while (setq E (xdrx_getentdata 0))
          (xdrx_pbarsetpos N)
          (setq N (1+ N))
          (#CHG_DXF E NUM0 NUM)
          (entupd E)
        (xdrx_pbarend)
    (xdrx_end)
    (setvar "dimclrd" HOLDCLRD)
    (setvar "dimclrt" HOLDCLRT)
;;;背景颜色
  (defun BACK (/ NOS N AAA A1)
    (setq NOS (dos_getcolor "设定背景颜色" 7))
    (setq N 2)
    (setq AAA "")
    (repeat 3
      (if (= (DECIMALTOBASE 16 (nth N NOS)) "")
        (setq A1 "00")
        (setq A1 (DECIMALTOBASE 16 (nth N NOS)))
      (setq AAA (strcat AAA A1))
      (setq N (1- N))
    (setq COLOR (BASETODECIMAL 16 AAA))
  (command "_.undo" "m")
  (vl-load-com)
  (setq ACADOBJECT (vlax-get-acad-object))
  (setq PREF (vla-get-preferences ACADOBJECT))
  (setq PREF_DISPLAY (vla-get-display PREF))
  (setq PT1 (getpoint "\n框选第一点: "))
  (setq PT2 (getcorner PT1 "\n框选第二点: \n"))
  (if (= (getvar "CVPORT") 2)
      (setq HOLDCOLOR
             (vla-get-graphicswinlayoutbackgrndcolor PREF_DISPLAY)
      (setq HOLDVIEWPORT (vla-get-layoutcreateviewport PREF_DISPLAY))
      (vla-put-layoutcreateviewport PREF_DISPLAY :vlax-false)
      (command "_layout" "new" "layout_temp")
      (setvar "ctab" "layout_temp")
      (command "_.mview" PT1 PT2)
      (command "_.zoom" "W" PT1 PT2)
      (command "_.mspace")
      (command "_.regen")
      (if (= FLAG 1)
          (DWGBLACK PT1 PT2)
          (BACK)
        (setq COLOR 16777215)
      (command "_.regen")
      (vla-put-graphicswinlayoutbackgrndcolor
        PREF_DISPLAY
        COLOR
      (command "_.copyclip" "C" PT1 PT2 "")
        PREF_DISPLAY
        HOLDCOLOR
      (vla-put-layoutcreateviewport PREF_DISPLAY HOLDVIEWPORT)
      (setq HOLDCOLOR
      (command "_.regen")
      (if (= FLAG 1)
          (LRBT PT1 PT2)
          (DWGBLACK PT1 PT2)
          (BACK)
      (command "_.regen")
        PREF_DISPLAY
        COLOR
        PREF_DISPLAY
        HOLDCOLOR
  (command "_.undo" "b")
(defun C:CLIP_WORD () (CLIP 0))
(defun C:CLIP_WORD_COLOR () (CLIP 1))
(prompt
  "\nType CLIP_WORD for 快速剪贴 , Type CLIP_WORD_COLOR for 设定颜色 "
 楼主| 发表于 2002-4-15 10:53:00 | 显示全部楼层
不行啊
首先感谢各位。
但我刚刚学起,所以看不懂。
另外,这个程序是不是LIST编写的。我必须用VBA实现。
请各位指教。谢谢。
GMT+8, 2026-1-21 04:32 , Processed in 0.145458 second(s), 26 queries , Gzip On.
