查看: 2965|回复: 14
[LISP]请高手帮忙,还是标注边长的程序
发表于 2005-8-12 09:27:00 | 显示全部楼层 |阅读模式
诸位大哥,我在绘图时标注多边形边长经常是一个边、一个边的标注边长,这样工作起来就非常麻烦。
劳驾诸位大哥,能不能编一个程序,使得标注边长更加方便、快捷。
谢谢!
发表于 2005-8-12 11:30:00 | 显示全部楼层
请试用。
  1. (DEFUN C:DIMPL ()
  2. (SETVAR "CMDECHO" 0)
  3. (SETQ OLDOS (GETVAR "OSMODE"))
  4. (COMMAND ".UNDO" "BE")
  5. (SETVAR "OSMODE" 0)
  6. (PROMPT "\nSelect lwpolyline :")
  7. (IF (SETQ SS (SSGET '((0 . "LWPOLYLINE")))) (PROGN
  8.   (SETVAR "DIMSD1" 1)  (SETVAR "DIMSD2" 1)
  9.   (SETVAR "DIMSE1" 1)  (SETVAR "DIMSE2" 1)
  10.   (SETQ SL (SSLENGTH SS) I 0)
  11.   (REPEAT SL
  12.    (SETQ LC (ENTGET (SSNAME SS I)) I (1+ I))
  13.    (SETQ LL (LENGTH LC) J 0 N (CDR (ASSOC 90 LC))
  14.          CL (CDR (ASSOC 70 LC)) K 1)
  15.    (WHILE (< J LL)
  16.     (IF (/= (CAR (NTH J LC)) 10) (SETQ J (1+ J)) (SETQ LL J))
  17.    )
  18.    (SETQ P1 (CDR (NTH J LC)) PS P1)
  19.    (WHILE (< K N)
  20.     (SETQ P2 (CDR (NTH (+ J (* K 4)) LC)))
  21.     (COMMAND "DIMALIGNED" P1 P2 P2)
  22.     (SETQ P1 P2 K (1+ K))
  23.    )
  24.    (IF (= CL 1) (COMMAND "DIMALIGNED" P1 PS P1))
  25.   )
  26.   (SETVAR "DIMSD1" 0)  (SETVAR "DIMSD2" 0)
  27.   (SETVAR "DIMSE1" 0)  (SETVAR "DIMSE2" 0)
  28. ))
  29. (COMMAND ".UNDO" "E")
  30. (SETVAR "OSMODE" OLDOS)
  31. (SETVAR "CMDECHO" 1)
  32. (PRINC)
  33. )
复制代码
 楼主| 发表于 2005-8-12 13:01:00 | 显示全部楼层
多谢大哥的程序。
这个程序很好,但还是有个问题,就是在标注边长的时候有的边长在多边形的外侧,有的边长在多边形的内侧。
请问,能不能把所有的边长标注都调整为外侧呢?
谢谢!!!
发表于 2005-8-12 13:36:00 | 显示全部楼层
跟你说了很多次了,让你不要一个问题发多个帖
  1. (defun c:Dimline( / dir gap ss i ent ents pts)
  2.   (vl-load-com)
  3.   (setq dir (getstring "\n选择方向[(A)顺时针外部/(B)顺时针内部](逆时针则相反)<A>:"))
  4.   (setq gap (getreal "\n输入标注文字到边边距离:"))
  5.   (if (= (strcase dir) "B")
  6.     (setq dir 0)
  7.     (setq dir pi)
  8.   )
  9.   (setq ss (ssget '((0 . "LWPOLYLINE"))))
  10.   (setq i 0)
  11.   (setvar "cmdecho" 0)
  12.   (if ss
  13.     (progn
  14.       (repeat (sslength ss)
  15. (setq ent (ssname ss i))
  16. (setq ents (entget ent))
  17. (setq pts (mapcar 'cdr (vl-remove-if-not '(lambda (e) (= (car e) 10)) ents)))
  18. (mapcar '(lambda(e1 e2) (command "_.dimaligned" e1 e2 (polar e1 (+ dir (angle e1 e2) (/ pi 2.0)) gap)))
  19.    pts (append (cdr pts) (list (car pts))))
  20. (setq i (1+ i))
  21.       )
  22.     );progn
  23.   );if
  24.   (princ)
  25. )
 楼主| 发表于 2005-8-12 13:46:00 | 显示全部楼层
真对不起!
因为没人理我,我才多发了几个帖子。
 楼主| 发表于 2005-8-12 13:51:00 | 显示全部楼层
下次改正
 楼主| 发表于 2005-8-12 14:04:00 | 显示全部楼层
按顺时针标注时,当线的角度大于行等于180度时,怎样才能把长度标注在线段的另一侧呢?
发表于 2005-8-12 19:00:00 | 显示全部楼层
标注样式中修改,如图,选择外部
 楼主| 发表于 2005-8-12 19:31:00 | 显示全部楼层
我的意思是指:
在您的标注边长的程序中,我按顺时针标注多边形时,当线段的角度小于180度时,边长的标注就会在多边形的外侧,线段的角度大于等于180度时就会在内侧,我想让它统一标注在多边形的外侧(不管线段的角度是否小于、等于、大于180度,都要标注在多边形的外侧),在您的程序中该怎样实现呢?
谢谢!!!
发表于 2005-8-15 13:52:00 | 显示全部楼层
我的程序就是按你的要求啊,不会由于180而改变啊,看图:
GMT+8, 2025-5-25 16:51 , Processed in 0.198450 second(s), 27 queries , Gzip On.
