查看: 1352|回复: 4
请教各位高手
发表于 2005-8-13 12:45:00 | 显示全部楼层 |阅读模式
不好意思,我是个新手,请教过程如何调用?
Sub drawcirculkarpavers()
Dim center As AcadPoint, radius As Double
Dim counter As Integer
With ThisDrawing.Utility
center = .GetPoint(, "click the position for center.")
radius = .GetDistance(center, "enter the radius")
End With
For counter = 0 To TextBox1 - 1
Set birckcircles(Count) = ThisDrawing.ModelSpace.AddCircle(center, radius - counter * radius / TextBox1)
brickcircles(counter).Color = acRed
brickcircles(counter).Update
drawmortar center, counter, radius
Next
End Sub
Sub drawmortar(center As AcadPoint, counter As interger, radius As Double)
Dim startpoint(0 To 2) As Double, endpoint(0 To 2) As Double
Dim theta As Double, stepsize As Double
Static adjust As Double
If User = True Then
stepsize = 15 * pi / 180
Else
stepsize = 30 * pi / 180
If adjust = 0 Then
adjust = 15 * pi / 180
Else
adjust = 0
End If
End If
For theta = 0 To 360 * pi / 180 Step stepsize
startpoint(0) = (radius - counter * radius / TextBox1) * Cos(theta + adjust) + center(0)
startpoint(1) = (radius - counter * radius / TextBox1) * Sin(theta + adjust) + center(1)
endpoint(0) = (radius - (counter + 1) * radius / TextBox1) * Cos(theta + adjust) + center(0)
endpoint(1) = (radius - (counter + 1) * radius / TextBox1) * Sin(theta + adjust) + center(1)
With ThisDrawing.ModelSpace
.AddLine startpoint, endpoint
.Item(.Count - a).Update
End With
Next
End Sub
编译老是通不过,说红色的部分未定义,不知如何修改,谢谢!
发表于 2005-8-14 17:23:00 | 显示全部楼层
可能的话,把整个工程打包发给我看看吧。
从你这上面看的话,没有错。
Email:
uhuang@163.com
 楼主| 发表于 2005-8-14 21:52:00 | 显示全部楼层
好的,谢谢先
发表于 2005-8-14 22:06:00 | 显示全部楼层
程序太乱了些。问题很多,因为没有贴完整,很难调试。
如果只是你所说的问题,那是因为你把
中的integer写成了interger
 楼主| 发表于 2005-8-15 09:17:00 | 显示全部楼层
好的,谢谢!
GMT+8, 2025-5-5 09:09 , Processed in 0.171144 second(s), 23 queries , Gzip On.
