查看: 3545|回复: 10
[LISP] 寻求AUTOLISP图元体与群码表的详细分析资料 谢谢
发表于 2005-8-15 09:12:00 | 显示全部楼层 |阅读模式
诸位大哥:
我刚开始学AUTOLISP,需要AUTOLISP图元体与群码表的详细分析资料,哪位大哥能帮帮我吗?
谢了!!!
 楼主| 发表于 2005-8-15 09:28:00 | 显示全部楼层
请问:no function definition: UREAL是什么意思呀?
 楼主| 发表于 2005-8-15 09:34:00 | 显示全部楼层
以上问题是我在运行以下程序时出现的。
ztmj.lsp 总图面积
* C:ztmj
-- xyp@bsedi.com
2004.09.30
(prompt "\n\r      加载总图面积程序。")
;;;主程序
(defun c:ztmj (/ pt pt1 en aa bl-bz)
  (cmdla0)
  (princ "\n注意绘图单位 : 1=1米")
  (SETBL1)
  (setq h (* SC 300))
  (COMMAND "style" "宋体" "宋体" h "0.7" "0" "" "")
  (initget "A B C")
  (setq
    BL-bz (getkword "\n请选择标注单位 A-平方米/B-亩/C-公顷.<平方米>:")
  (initget "Y N")
  (setq bz2 (getkword "需要标注单位名称吗?Y/<N>"))
  (setq pt (getpoint "\n选取封闭域内一点: "))
  (while pt
    (setq pt1 pt)
    (mkla "封闭域辅助线" 8)
    (command "bpoly" pt "")
    (setq en (entlast))
    (if (/= en nil)
 (command "area" "o" en)
 (setq aa (getvar "area"))
 ;;(redraw en 3)
 ;|1标准2空白3高亮4低亮
 此句可以显示面积数(单位平方米)
 如果是总图或测量专业,画图单位为米时,下句中1000000.0应改为1.0
 (alert (strcat "面积=" (rtos (/ aa 1000000.0) 2 2)))
    (entdel en)
    ;;此句可以决定是否删除“封闭域辅助线”
    (mkla "面积标注" 4)
    (setq bz2 (if bz2
  bz2
  "N"
    (if (= bz2 "N")
 (setq BL-bz (if BL-bz
        BL-bz
        "A"
 (if (= bl-bz "A")
   (setq aa (rtos (/ aa 1.0) 2 2))
 (if (= bl-bz "B")
   (setq aa (rtos (/ aa (/ 2000.0 3)) 2 2))
 (if (= bl-bz "C")
   (setq aa (rtos (/ aa 10000.0) 2 4))
        BL-bz
        "A"
 (if (= bl-bz "A")
   (setq aa (strcat (rtos (/ aa 1.0) 2 2) "平方米"))
 (if (= bl-bz "B")
   (setq aa (strcat (rtos (/ aa (/ 2000.0 3)) 2 2) "亩"))
 (if (= bl-bz "C")
   (setq aa (strcat (rtos (/ aa 10000.0) 2 4) "公顷"))
    (command "text" "j" "mc" pt1 "0" aa)
  (cmdla1)
  ;;(pxyp"ztmj      (总图面积)")
;;;子程序
(defun CMDLA0 ()
  (setq cmdech (getvar "CMDECHO"))
  (setq oom (getvar "orthomode"))
  (setq osm (getvar "osmode"))
  (SETQ LA (getvar "clayer"))
  (setq rmode (getvar "regenmode"))
  (setvar "regenmode" 0)
  (setvar "CMDECHO" 0)
(defun CMDLA1 ()
  (setvar "CMDECHO" cmdech)
  (setvar "orthomode" oom)
  (setvar "osmode" osm)
  (setvar "clayer" LA)
  (setvar "regenmode" rmode)
(Defun MKLA (a b)
  (If (= (Tblsearch "layer" a) nil)
    (Command "layer" "m" a "c" b a "")
    (Command "layer" "t" a "s" a "c" b a "")
;;;* SET BL & SC. 设置总图出图比例及比例系数。
(defun setbl1 ()
  ;;(while (OR (= BL NIL) (> bl 3))
  ;;(GRTEXT -1 "总图以米为单位, 请注意!!!" 1)
  ;;(setq bl (ureal 1 ""  "\n\t输入出图比例1 " bl))
  (setq bl (ureal 1 "" "\n输入出图比例1 : " bl))
  (setq SC (/ bl 100))
  (command "modemacro"
    (strcat "XCAD BY XYP." " 当前出图比例 1:" (rtos bl 2 1))
(DEFUN Pxyp (TXT1)
  (SETQ TXT1 (STRCAT "\n\r      程序命令: "
       TXT1
       "      -- xyp@bsedi.com"
  (PRINC TXT1)
  (Princ)
;;;defun
(pxyp "ztmj      (总图面积)")
;;;END
发表于 2005-8-15 09:54:00 | 显示全部楼层
兄弟,在程序中这一句“ (setq bl (ureal 1 "" "\n输入出图比例1 : " bl))”
ureal该函数名未定义
发表于 2005-8-15 10:17:00 | 显示全部楼层
    ;* UREAL User interface real function
    ;* BIT (0 for none) and KWD key word ("" for none) are same as for INITGET.
    ;* MSG is the prompt string, to which a default real is added as <DEF> (nil
    ;* for none), and a : is added.
    (defun ureal (bit kwd msg def / inp)
       (if def                                                  ;test for a default
         (setq msg (strcat "\n >> " msg " < " (rtos def 2) " >: ")     ;string'em with default
               bit (* 2 (fix (/ bit 2)))  ;a default & no null bit code conflict so
         )                                ;this reduces bit by 1 if odd, to allow null
         (if (= " " (substr msg (strlen msg) 1))            ;no def, if last char is space
           (setq msg (strcat "\n >> " (substr msg 1 (1- (strlen msg))) " : ")) ;then strip space
           (setq msg (strcat "\n >> " msg " : "))                ;else msg OK
       ) );if,if
       (initget bit kwd)
       (setq inp (getreal msg))           ;the GETREAL function
       (if inp inp def)                   ;compare the results, return appropriate value
    );defun
 楼主| 发表于 2005-8-15 10:46:00 | 显示全部楼层
谢谢各位大哥相助!!!
请问有AUTOLISP图元体与群码表的详细分析资料吗?   谢谢
发表于 2005-8-15 17:38:00 | 显示全部楼层
 楼主| 发表于 2005-8-15 21:40:00 | 显示全部楼层
大哥呀大哥,求你饶了小弟吧。那是一个收费网站,要了小弟的命我也没钱啊!!!
 楼主| 发表于 2005-8-15 21:43:00 | 显示全部楼层
诸位大哥救我呀!!!
发表于 2005-8-15 22:41:00 | 显示全部楼层
GMT+8, 2025-8-13 05:34 , Processed in 0.195234 second(s), 25 queries , Gzip On.
