查看: 1845|回复: 0
请高手出招!CAcUiDockControlBar问题!
发表于 2005-8-15 16:40:00 | 显示全部楼层 |阅读模式
用CAcUiDockControlBar向CAD中加入自己的ControlBar出现问题,请各位高手急救!
我创建了一个基于CAcUiDockControlBar的类,在类中创建自己的控件。加载到CAD后,让其自己停靠,但是停靠后的工具条高度无法所到。另外加载后CAD出现不停闪烁现象,请高手出招!
 class CLayerDockControlBar : public CAcUiDockControlBar
 DECLARE_DYNAMIC(CLayerDockControlBar)
public:
 CLayerDockControlBar();
public:
 virtual BOOL Create(CWnd* pParent, LPCSTR lpszTitle);
protected:
 afx_msg int OnCreate (LPCREATESTRUCT lpCreateStruct);
 afx_msg void OnSize(UINT nType, int cx, int cy);
 DECLARE_MESSAGE_MAP()
 virtual void SizeChanged(CRect *lpRect, BOOL bFloating, int flags);
public:
 CLayerManageBar *m_pWndLayerBar;
IMPLEMENT_DYNAMIC(CLayerDockControlBar, CAcUiDockControlBar)
BEGIN_MESSAGE_MAP(CLayerDockControlBar, CAcUiDockControlBar)
//{{AFX_MSG_MAP(CLayerDockControlBar)
ON_WM_CREATE()
ON_WM_SIZE()
//}}AFX_MSG_MAP
END_MESSAGE_MAP()
static CLSID clsCLayerDockControlBar ={  0x45d8e5de, 0xaa69, 0x4611, { 0x8f, 0xeb, 0xb2, 0xa6, 0xbe, 0xe8, 0xfb, 0x47 } } ;
CLayerDockControlBar::CLayerDockControlBar()
: CAcUiDockControlBar()
 m_pWndLayerBar = NULL;
BOOL CLayerDockControlBar::Create(CWnd* pParent, LPCSTR lpszTitle)
 CString strWndClass;
 strWndClass = AfxRegisterWndClass (CS_DBLCLKS, LoadCursor (NULL,  IDC_ARROW));
 CRect rect (0, 0, 158, 300);
 if ( !CAcUiDockControlBar::Create(
  strWndClass,
  lpszTitle,
  WS_VISIBLE | WS_CHILD | WS_CLIPCHILDREN,
  rect,
  pParent, IDC_TOOLBAR_LAYERMANAGER
  return (FALSE);
 SetToolID (&clsCLayerDockControlBar) ;
 return (TRUE);
int CLayerDockControlBar::OnCreate (LPCREATESTRUCT lpCreateStruct)
 if ( CAcUiDockControlBar::OnCreate (lpCreateStruct) == -1 )
  return (-1);
 CAcModuleResourceOverride resourceOverride;
 m_pWndLayerBar = new CLayerManageBar;
 if (!m_pWndLayerBar->Create(_T("Layer Manager"), this, CSize(200,300),TRUE,123))
  return -1;
 m_pWndLayerBar->SetBarStyle(m_pWndLayerBar->GetBarStyle() |
  CBRS_TOOLTIPS | CBRS_FLYBY | CBRS_SIZE_DYNAMIC);
 m_pWndLayerBar->AddView(RUNTIME_CLASS(CWndSliderView));
 ((CWndSliderView *)m_pWndLayerBar->GetActiveView())->CreateView("0 LayView", RUNTIME_CLASS(CLayerManagerView), NULL);
 ((CWndSliderView *)m_pWndLayerBar->GetActiveView())->CreateView("1 LayView", RUNTIME_CLASS(CLayerManagerView), NULL);
 return (0);
void CLayerDockControlBar::OnSize(UINT nType, int cx, int cy)
 CAcUiDockControlBar::OnSize(nType, cx, cy);
 if(m_pWndLayerBar)
  if(!IsFloating())
   m_pWndLayerBar->MoveWindow(0, 20, cx, cy-20);
void CLayerDockControlBar::SizeChanged(CRect *lpRect, BOOL bFloating, int flags)
 if (m_pWndLayerBar != NULL)
  m_pWndLayerBar->MoveWindow(0,20,lpRect->right, lpRect->bottom-20);
以下为调用部份。
static CLayerDockControlBar *dockBar = NULL;
void LayerManager()
 CAcModuleResourceOverride res;
 if (dockBar == NULL)
  dockBar = new CLayerDockControlBar;
  dockBar->Create(acedGetAcadFrame(), "MyDockBar");
  dockBar->SetWindowText( _T("HELLO"));
 dockBar->EnableDocking(CBRS_ALIGN_ANY);
 acedGetAcadFrame()->EnableDocking(CBRS_ALIGN_ANY);
 acedGetAcadFrame()->DockControlBar(dockBar, AFX_IDW_DOCKBAR_LEFT);
 acedGetAcadFrame()->ShowControlBar(dockBar, TRUE, TRUE);
 SetActiveWindow(acedGetAcadFrame()->m_hWnd);
GMT+8, 2025-5-8 23:38 , Processed in 0.174881 second(s), 23 queries , Gzip On.
