我想要使用activex方式画一个方形,图可以画出来,可是当我观看它的群码,却发现群码的内容不完整,只能显示到第一个坐标值,其它点的坐标竟然消失了,可是画出来的图并没错,请问这是什么原因呢?
程序代码:
(defun test() (vl-load-com) (setq acadobject (vlax-get-acad-object)) (setq dwgs (vla-get-activedocument acadobject)) (setq mspace (vla-get-modelspace dwgs)) (setq VLADataPts (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-vbdouble (cons 0 14)) '(0 0 0 0 127000 0 127000 127000 0 127000 0 0 0 0 0)))) (vla-Addpolyline mspace VLADataPts) (princ) )
群码:
Select object: ((-1 . <Entity name: 7ef5ef90>) (0 . "POLYLINE") (330 . <Entity name: 7ef5ecf8>) (5 . "EA") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (100 . "AcDb2dPolyline") (66 . 1) (10 0.0 0.0 0.0) (70 . 0) (40 . 0.0) (41 . 0.0) (210 0.0 0.0 1.0) (71 . 0) (72 . 0) (73 . 0) (74 . 0) (75 . 0)) |
