查看: 2482|回复: 4
请教:如何在程序里判断我“按下鼠标右键”?
发表于 2005-8-17 14:31:00 | 显示全部楼层 |阅读模式
请问,如何在程序里判断我“按下鼠标右键”?通过这样的判断我可以从某个过程中退出来
 楼主| 发表于 2005-8-18 16:10:00 | 显示全部楼层
难道这是个很难的问题吗?
怎么没有人回答呀
发表于 2005-8-18 19:48:00 | 显示全部楼层
按下右键会产生一个错误,通过捕获错误号知道。具体这方面的源代码网站上有,你搜索一下。
发表于 2005-8-19 08:48:00 | 显示全部楼层
参考一下:
Public Function ClickConfirm() As Boolean
  Dim objUtil As AcadUtility
  Dim varPnt As Variant
  Dim strPrmt As String
  On Error GoTo Err_Control
  ‘strPrmt = "Left click to confirm, right click to cancel"
  strPrmt = "鼠标左键确认,右键取消"
  Set objUtil = ThisDrawing.Utility
  varPnt = objUtil.GetPoint(Prompt:=strPrmt)
  'No error? Then they "left clicked" (or typed a point on
  'The command line. Meh. Users are crazy.
  ClickConfirm = True
Exit_Here:
  Exit Function
Err_Control:
  'Debug.Print Err.Description; Err.Number
  Select Case Err.Number
    Case -2145320928
    'Right click with command prompt or "Enter" key
    'User input is a keyword
      Err.Clear
      Resume Exit_Here
    Case -2147352567
    'User pressed escape or clicked a toolbar
    'Method 'GetPoint' of object 'IAcadUtility' failed
      Err.Clear
      Resume Exit_Here
    Case Else
      Err.Clear
      Resume Exit_Here
  End Select
End Function
功能
实现鼠标左键确认,右键取消功能
语法
ClickConfirm()
返回值
True为按了左键
 楼主| 发表于 2005-8-19 10:15:00 | 显示全部楼层
谢谢你们,我马上去搞一下。
GMT+8, 2025-5-5 08:57 , Processed in 0.178074 second(s), 23 queries , Gzip On.
