查看: 1904|回复: 4
[VBA]flexgrid控件问题
发表于 2005-8-21 15:52:00 | 显示全部楼层 |阅读模式
我在vb中运行以下的程序好用,但是在vba中运行的时候总是提示我错误信息“对象不可用”
请斑竹和各位指教~~
程序主要用的是一个flexgrid控件,想实现在第一、二行中,单击左键,会出现一文字框
而第三、四行,会出现选择类表单(ComboBox)输入完毕后按下Enter键,资料即可保留于MSFlexGrid中,而按下Esc键则取消输入
Option Explicit
Private Sub Combo1_Change()
End Sub
Private Sub Combo1_Exit(ByVal Cancel As MSForms.ReturnBoolean)
Combo1.Visible = False
'MSFlexGrid1.SetFocus
End Sub
Private Sub Combo1_KeyPress(ByVal KeyAscii As MSForms.ReturnInteger)
Dim i As Integer, bSame As Boolean
If KeyAscii = vbKeyEscape Then
    Exit Sub
End If
If KeyAscii = vbKeyReturn Then
    MSFlexGrid1.text = Combo1.text
    With Combo1
        bSame = False
        For i = 0 To .ListCount
            If .text = .List(i) Then bSame = True
        Next i
        If Not bSame Then .AddItem .text
    End With
End If
End Sub
Private Sub MSFlexGrid1_Click()
Dim c As Integer, r As Integer
With MSFlexGrid1
    c = .Col: r = .Row
    If r <= 2 Then
        Text1.Left = .Left + .ColPos(c)
        Text1.Top = .Top + .RowPos(r)
        Text1.width = .ColWidth(c)
        Text1.height = .RowHeight(r)
        Text1 = .text
        Text1.Visible = True
        Text1.SetFocus
    Else
        Combo1.Left = .Left + .ColPos(c)
        Combo1.Top = .Top + .RowPos(r)
        Combo1.width = .ColWidth(c)
        Combo1.text = .text
        Combo1.Visible = True
        Combo1.SetFocus
    End If
End With
End Sub
Private Sub MSFlexGrid1_KeyPress(KeyAscii As Integer)
    Call MSFlexGrid1_Click
End If
End Sub
Private Sub Text1_Change()
End Sub
Private Sub Text1_Exit(ByVal Cancel As MSForms.ReturnBoolean)
Text1.Visible = False
End Sub
Private Sub Text1_KeyPress(ByVal KeyAscii As MSForms.ReturnInteger)
    Exit Sub
End If
    MSFlexGrid1.text = Text1.text
End If
End Sub
Private Sub UserForm_Initialize()
Dim i As Integer
With MSFlexGrid1
    .Cols = 5
    .Rows = 5
    For i = 0 To 4
        .RowHeight(i) = 300
    Next i
End With
For i = 1 To 10
    Combo1.AddItem i
Next i
Label1.Caption = "在第一、二行中,双击左键,会出现一文字框(TextBox)..." & vbCr & _
                 "而第三、四行,会出现选择类表单(ComboBox)..." & vbCr & _
                 "输入完毕后按下Enter键,资料即可保留于MSFlexGrid中," & vbCr & _
                 "而按下Esc键则取消输入..."
End Sub
 楼主| 发表于 2005-8-21 15:54:00 | 显示全部楼层
程序代码
 楼主| 发表于 2005-8-21 19:48:00 | 显示全部楼层
怎么没有人回答阿~
发表于 2005-8-25 11:18:00 | 显示全部楼层
用用VSFLEXGRID控件看看,也许只要几行代码就可以搞定。
 楼主| 发表于 2005-8-26 14:50:00 | 显示全部楼层
to:ntchjie
 请问在VBA中怎样用VSFLEXGRID控件怎么快速实现我要的功能?
GMT+8, 2025-5-5 06:29 , Processed in 0.139924 second(s), 24 queries , Gzip On.
