查看: 2286|回复: 1
[求助]如何获取用insert插入的属性块的各属性值(块名已知)
发表于 2005-8-22 10:09:00 | 显示全部楼层 |阅读模式
发表于 2005-8-22 10:47:00 | 显示全部楼层
这是一本书中的例子,每一行代码的例子我还不太懂,你自己看看吧.其中包括插入块的代码.
void insrtBlk()
 char blkName[50];
 AcDbDatabase *pCurDb;
 AcDbBlockTable *pBlkTable;
 AcDbBlockTableRecord *pBlkTableRecord;
 AcDbBlockTableRecord *pBlkDefRecord;
 AcDbBlockReference *pInsrtObj;
 AcDbEntity *pEnt;
 AcDbBlockTableRecordIterator *pIterator;
 AcDbAttributeDefinition *pAttDef;
 AcDbAttribute *pAtt;
 AcDbObjectId blkId;
 AcDbObjectId insrtId;
 char *pTagPrompt;
 AcGePoint3d insPt;
 AcGePoint3d basePt;
 int retCode;
 retCode = acedGetString(0, "\nEnter Block Name: ", blkName);
 if(retCode != RTNORM || blkName[0] == '\0')
  acutPrintf("\nInvalid block name.");
  return;
 pCurDb = acdbHostApplicationServices()->workingDatabase();
 // Check to see if the block table
 // has blkName
 pCurDb->getBlockTable(pBlkTable, AcDb::kForRead);
 if(!pBlkTable->has(blkName))
  acutPrintf("\nBlock definition %s not found. ", blkName);
  pBlkTable->close();
  return;
 // Get the AcDbObjectId of the block
 // definition.
 pBlkTable->getAt(blkName, blkId);
 pBlkTable->getAt(ACDB_MODEL_SPACE, pBlkTableRecord, AcDb::kForWrite);
 pBlkTable->close();
 acedInitGet(RSG_NONULL, NULL);
 acedGetPoint(NULL, "\nPick insertion point: ", asDblArray(insPt));
 pInsrtObj = new AcDbBlockReference(insPt, blkId);
 // Here is where you can set scale, rotation and other
 // properties to the block entity. If you want to
 // see the AcDbBlockReference class for more details.
 pBlkTableRecord->appendAcDbEntity(insrtId, pInsrtObj);
 acdbOpenObject(pBlkDefRecord, blkId, AcDb::kForRead);
 // Now check to see if the Block Definition
 // has attributes. If it does we will add
 // a Block Table Record Iterator to step through
 // the entities and find the Attribute Definitions.
 if(pBlkDefRecord->hasAttributeDefinitions())
  pBlkDefRecord->newIterator(pIterator);
  for(pIterator->start(); !pIterator->done(); pIterator->step())
   pIterator->getEntity(pEnt, AcDb::kForRead);
   // Check to see if the entity is an
   // attribute definition.
   pAttDef = AcDbAttributeDefinition::cast(pEnt);
   if(pAttDef != NULL && !pAttDef->isConstant())
    // If it is and its not constant
    // create a new attribute
    pAtt = new AcDbAttribute();
    // setPropertiesFrom will copy
    // Color, Layer, Linetype,Linetype scale and
    // Visibility.
    pAtt->setPropertiesFrom(pAttDef);
    // setup more properties from the attribute
    // definition
    pAtt->setInvisible(pAttDef->isInvisible());
    basePt = pAttDef->position();
    basePt += pInsrtObj->position().asVector();
    pAtt->setPosition(basePt);
    pAtt->setHeight(pAttDef->height());
    pAtt->setRotation(pAttDef->rotation());
    // Take note how we get the tag.
    pTagPrompt = pAttDef->tag();
    pAtt->setTag(pTagPrompt);
    free(pTagPrompt);
    // Normally you would prompt the user
    // and ask for input values.
    pTagPrompt = pAttDef->prompt();
    acutPrintf("%s%s", "\n", pTagPrompt);
    free(pTagPrompt);
    // The setFieldLength is not required
    // even though it is listed in the
    // documentation.
    pAtt->setFieldLength(25);
    // setTextString is the value the
    // attribute receives which would
    // normally be a user input value.
    pAtt->setTextString("This is a test");
    pInsrtObj->appendAttribute(pAtt);
    pAtt->close();
   pEnt->close();
  }// for
  delete pIterator;
}// if has attribute definitions
  // Note that we close the Model Space
 // block table record after we have added
 // our attributes.
 pBlkTableRecord->close();
 pInsrtObj->close();
GMT+8, 2025-5-8 21:56 , Processed in 0.143770 second(s), 24 queries , Gzip On.
