查看: 1774|回复: 5
[LISP]求助一个生成圆的程序
发表于 2005-8-25 08:37:00 | 显示全部楼层 |阅读模式
诸位大哥,我想寻求这样一个程序,就是在PLINE线的每一个拐点处生成一个圆(圆的半径可以任意设定)
谢谢各位!!!
发表于 2005-8-25 09:16:00 | 显示全部楼层
拐点?节点?
发表于 2005-8-25 12:06:00 | 显示全部楼层
;试用以下程序
(defun c:cc()
    (setq cm (getvar "cmdecho") os (getvar "osmode"))
    (setvar "cmdecho" 0)
    (setq ent (entsel "\n请选择pline:"))
    (if ent
    (setq ent (car ent)
   nam (cdr (assoc 0 (entget ent)))
    (redraw ent 3)
    (if (member nam '("LWPOLYLINE" "POLYLINE"))
                  (setq r (getdist "\n请输入圆的半径:"))
    (redraw ent 4)
    (if (= nam "LWPOLYLINE")
        (setq ptb (vl-remove 'nil
                                  (mapcar '(lambda(x)(if (= (car x) 10)(cdr x)))
        (entget ent)
    (setq ptb nil  ent (entnext ent)  pt (entget ent))
                         (while (/= (cdr (assoc 0 pt)) "SEQEND")
       (setq pt  (entget ent)
      ptb (append ptb (list (cdr (assoc 10 pt))))
      ent (entnext ent)
    (setq ptb (vl-remove 'nil ptb))
    (setvar "osmode" 0)
    (foreach pt ptb
       (command "_circle" pt r "chprop" (entlast) "" "c" "1" "")
        (progn (alert "你选择的不是pline(LWPOLYLINE或者POLYLINE)!")
        (redraw ent 4)
        (alert "你没有选择任何图元!")
    (setvar "cmdecho" cm)(setvar "osmode" os)(princ)
发表于 2005-8-25 14:29:00 | 显示全部楼层
小弟不明白,程序中(redraw ent 3) 是做什么用的.
请高手指点一二.谢过
 楼主| 发表于 2005-8-25 14:37:00 | 显示全部楼层
谢谢了!非常实用!!!!
发表于 2005-8-25 15:14:00 | 显示全部楼层
"(redraw ent 3)"作用是将所选中的图元高亮度显示。
GMT+8, 2025-8-13 05:34 , Processed in 0.184031 second(s), 25 queries , Gzip On.
