对3楼的说明补充几个问题:
defun c:cb() (setq s1 (getpoint "n/输入第一点"));;-----------------n/应改为\n 以下同 (setq s2 (list(+(car s1)2440)(cadr s1))) (setq s3 (list(+(car s1)2440)(+(cadr s1)1220))) (setq s4 (list(car s1)(+(cadr s1)1220))) (command "line" s1 s2 s3 s4 "c") ;;;画矩形为什么不用(command "_rectang) (setq v1 (getpoint "n/输入1长宽")) ;;;---------------n/应改为\n 以下同 (setq s5 (list(+(car s1) 5) (+(cadr s1) 5))) (setq s6 (list(+(car s1) 5 (car v1)) (+(cadr s1) 5))) (setq s7 (list(+(car s1) 5 (car v1)) (+(cadr s1) 5 (cadr v1)))) (setq s8 (list(+(car s1) 5) (+(cadr s1) 5 (cadr b1)))) (setq z1 (distance s1 s2)) (setq z2 (distance s1 s4)) (setq l1(distance s5 s6)) (setq l2(distance s5 s8)) (while (>= z1 l1) (setq z1 (- z1 (+ l1 5))) (command "line" s5 s6 s7 s8 "c") (setq s9 s5) (setq s10 s6) (setq s11 s7) (setq s12 s8) (while (>= z2 l2) (setq z2 (- z2 (+ l2 5))) (setq s9 (list(car s9) (+(cadr s9) l2 5)) (setq s10 (list(car s10) (+(cadr s10) l2 5)) (setq s11 (list(car s11) (+(cadr s11) l2 5)) (setq s12 (list(car s12) (+(cadr s12) l2 5)) (command "line" s9 s10 s11 s12 "c") (setq s5 (list(+(car s5) 5 l1)(cadr s5))) (setq s6 (list(+(car s6) 5 l1)(cadr s6))) (setq s7 (list(+(car s7) 5 l1)(cadr s7))) (setq s8 (list(+(car s8) 5 l1)(cadr s8))) ) ) )
