查看: 2114|回复: 4
[VBA]类型不匹配错误,紧急
发表于 2005-8-25 13:25:00 | 显示全部楼层 |阅读模式
                      'AutoCAD 2005 vba类型不匹配错误
Public Minpoint, Maxpoint As Variant
Private Sub cutphoto9_Click()
  Dim ClipPoints(0 To 99),POINTS(0 To 9),Clippoints1() As Double
  Dim kkkk As Integer
  Ssetobj.Item(0).GetBoundingBox Minpoint, Maxpoint
  number3 = Clipphoto(POINTS, ClipPoints, kkkk, Clippoints1)'调用函数
end sub
Public Function Clipphoto(Pone() As Double, Ptwo() As Double, su As Integer, PPPP() As Double) As Integer
  Dim Minx, Miny, Maxx, Maxy As Double
  Minx = Minpoint(0)'此句出现类型不匹配错误,请问怎么处理,把Minx 定义为Variant同样出错,有时又不会出错
End Function
发表于 2005-8-25 14:20:00 | 显示全部楼层
如此定义:
 楼主| 发表于 2005-8-25 18:35:00 | 显示全部楼层
我试了,还是报错
发表于 2005-8-25 21:05:00 | 显示全部楼层
Dim Minx As Double, Miny As Double, Maxx As Double, Maxy As Double
 楼主| 发表于 2005-8-27 20:32:00 | 显示全部楼层
多谢
GMT+8, 2025-5-5 06:12 , Processed in 0.155447 second(s), 23 queries , Gzip On.
