小弟是新手,我知道已经有很多前辈做过直接由线性模型生成实体模型的程序,不过没有看到过源代码。所以自己编了一个,发上来大家指点。还有一个问题没有解决,就是做管子相贯,没有思路,希望大家给个思路。
(defun c:ltog ()
(vl-load-com) (setq acadobject (vlax-get-acad-object) acaddocument (vla-get-activedocument acadobject) mspace (vla-get-modelspace acaddocument) ) (command "ucs" "") (setq ss1 (ssget '((0 . "*LINE,ARC")))) (setq n (sslength ss1)) (setq D (getreal "Input D:") ti (getreal "Input t: ") radius (/ D 2) ) (setq i 0) (while (< i n) (set (read (strcat "ssobj" (rtos i))) (vlax-ename->vla-object (ssname ss1 i)) ) (setq pnt1 (vlax-curve-getstartpoint (eval (read (strcat "ssobj" (rtos i)))) ) ) (setq point1 (vlax-make-safearray vlax-vbdouble '(0 . 2))) (vlax-safearray-fill point1 (list (nth 0 pnt1) (nth 1 pnt1) (nth 2 pnt1)) )
(setq pnt2 (vlax-curve-getendpoint (eval (read (strcat "ssobj" (rtos i)))) ) ) (command "ucs" "_zaxis" pnt1 pnt2) (setq circleobject1 (vla-addcircle mspace point1 radius)) (setq circleobject2 (vla-addcircle mspace point1 (- radius ti))) (setq curves (vlax-make-safearray vlax-vbobject '(0 . 1))) (vlax-safearray-fill curves (list circleobject1 circleobject2) ) (setq rgionobject (vla-addregion mspace curves)) (vla-boolean (vlax-safearray-get-element (vlax-variant-value rgionobject) 1 ) acsubtraction (vlax-safearray-get-element (vlax-variant-value rgionobject) 0 ) ) (setq rgionename (vlax-vla-object->ename (vlax-safearray-get-element (vlax-variant-value rgionobject) 1 ) ) ) (command "extrude" rgionename "" "p" (ssname ss1 i) ) (vla-regen acaddocument :vlax-true) (command "ucs" "p" "")
(setq i (1+ i)) ) ) (princ "这是一个直接将所选中线变成管子的程序,运行程序ltog") (prin1)
如果要其它截面的,原理是一样的,你也可以通过定义图层来自动生成。
不过,我还没有加入圆\椭圆线,希望大家补充。 |
