查看: 2014|回复: 2
如何生成坐标表
发表于 2005-8-29 09:27:00 | 显示全部楼层 |阅读模式
如图,如何自动生成一个一个统计表啊,关键是让x、y对应,要以这个闭合的线为路径,顺序排列在统计表中
发表于 2005-8-29 12:00:00 | 显示全部楼层
  1. ;试用以下程序
  2. (defun c:cc()
  3.     (setq cm (getvar "cmdecho") os (getvar "osmode"))
  4.     (setvar "cmdecho" 0)
  5.     (setq ent (car (entsel "\n请选择pline:"))
  6.           pt0 (getpoint "\n请指定坐标提取结果写入点:")
  7.    ptb (vl-remove 'nil
  8.     (mapcar '(lambda(x)(if (= (car x) 10) (cdr x)))
  9.              (entget ent)
  10.            )
  11.        )
  12.    i   0
  13.     )
  14.     (setvar "osmode" 0)
  15.     (foreach pt ptb
  16.         (command "text" (mapcar '+ pt0 (list 0  (* i -4))) 2.5 0 (rtos (car  pt) 2 3)
  17.                  "text" (mapcar '+ pt0 (list 20 (* i -4))) 2.5 0 (rtos (cadr pt) 2 3)
  18. )
  19.         (setq i (1+ i))
  20.     )
  21.     (setvar "cmdecho" cm)(setvar "osmode" os)(princ)
  22. )
 楼主| 发表于 2005-8-29 12:40:00 | 显示全部楼层
如果我要在其中增加几个非pline关键点的坐标的话,程序要怎么修改呢,
GMT+8, 2025-8-13 05:36 , Processed in 0.174744 second(s), 26 queries , Gzip On.
