查看: 2319|回复: 4
关于图形插入的问题
发表于 2005-9-1 15:27:00 | 显示全部楼层 |阅读模式
On Error Resume Next
   Set blkRefObj = ThisDrawing.ModelSpace.InsertBlock(blkIns, FileName, 1, 1, 1#, 0#)
      AutoCAD2006中出现错误,可以继续,担不给我插入图纸,Err.Number = -2145386422
好像2002中不怕,请高手指点。(vba编写)
发表于 2005-9-2 11:20:00 | 显示全部楼层
Paste more code please
 楼主| 发表于 2005-9-2 12:34:00 | 显示全部楼层
用insert 插入时,出现以下问题
command:i INSERT
Duplicate definition of block AR3_INFO  ignored.
Duplicate definition of block _DIMX  ignored.
Duplicate definition of block _ArchTick  ignored.
Duplicate definition of block AVE_RENDER  ignored.
Duplicate definition of block AVE_GLOBAL  ignored.
Duplicate definition of block RM_SDB  ignored.
Duplicate definition of block 1  ignored.
Duplicate definition of block 21  ignored.
Duplicate definition of block 23  ignored.
Specify insertion point or
[Basepoint/Scale/X/Y/Z/Rotate/PScale/PX/PY/PZ/PRotate]:
Regenerating model.
在2005以下版本中,用Set blkRefObj = ThisDrawing.ModelSpace.InsertBlock(blkIns, FileName, 1, 1, 1#, 0#)可以自动怱略,在2006中就出现了那个代码。
附文件,请用drawing3插入drawing2,可以看到问题存在
 楼主| 发表于 2005-9-2 12:35:00 | 显示全部楼层
drawing3
 楼主| 发表于 2005-9-3 16:44:00 | 显示全部楼层
有人可以指导一下吗?
GMT+8, 2025-5-5 04:22 , Processed in 0.161060 second(s), 24 queries , Gzip On.
