查看: 2028|回复: 5
关于屏幕菜单重定制的疑问
发表于 2005-9-3 09:49:00 | 显示全部楼层 |阅读模式
我想用vba程序重新定制屏幕菜单,使它实现我自己定制的功能,但是这方面的资料太少了,不知道哪位大哥知道,,能不能给点提示或示例代码,多谢大家了!!
发表于 2005-9-4 13:13:00 | 显示全部楼层
Public Sub createmenu()
Dim menugroupobject As AcadMenuGroup
Dim menuobject As AcadPopupMenu
Dim submenuobject1 As AcadPopupMenu
Dim submenuobject2 As AcadPopupMenu
Dim menuitemobject As AcadPopupMenuItem
Set menugroupobject = ThisDrawing.Application.MenuGroups.Item(0)
On Error Resume Next
Set menuobject = menugroupobject.Menus.Add("newdimensions")
Set submenuobject1 = menuobject.AddSubMenu(0, "linear")
Set submenuobject2 = menuobject.AddSubMenu(1, "angular")
Set menuitemobject = submenuobject1.AddMenuItem(menuobject.Count + 1, "aligned", "-vbarun thisdrawing.aligneddimension" & vbCr)
Set menuitemobject = submenuobject1.AddMenuItem(menuobject.Count + 1, "ordinate", "-vbarun thisdrawing.aordinatedimension" & vbCr)
Set menuitemobject = submenuobject1.AddMenuItem(menuobject.Count + 1, "rotated", "-vbarun thisdrawing.rotatedimension" & vbCr)
Set menuitemobject = submenuobject2.AddMenuItem(menuobject.Count + 1, "Angular", "-vbarun thisdrawing.angulardimension" & vbCr)
Set menuitemobject = submenuobject2.AddMenuItem(menuobject.Count + 1, "diametric", "-vbarun thisdrawing.diametricdimension" & vbCr)
Set menuitemobject = submenuobject2.AddMenuItem(menuobject.Count + 1, "radial", "-vbarun thisdrawing.radialdimension" & vbCr)
menuobject.InsertInMenuBar (ThisDrawing.Application.MenuBar.Count + 1)
End Sub
 楼主| 发表于 2005-9-5 09:25:00 | 显示全部楼层
多谢你的代码,,我收下仔细研读了!!!有什么问题再请教你
 楼主| 发表于 2005-9-5 12:55:00 | 显示全部楼层
我说的是屏幕菜单,不是普通的菜单。。在绘图区域,点击右键,选择选项,在显示选项卡上面有“显示屏幕菜单”的选项。选中就会出现屏幕菜单,现在的问题是如何自定制屏幕菜单???
 楼主| 发表于 2005-9-7 22:43:00 | 显示全部楼层
自己问题,自己回答!!!用记事本打开acad.mnu文件,找到***.screen,改写自己的菜单内容!!!!然后加载之!!!不过,要注意,最好另存acad.mnu,以免破坏autocad本身的系统。同样的,也可以加写自己的图象菜单,可以看图象做选择,同样在acad.mnu中,找到***.image,在下面添加自己的图象菜单。
发表于 2005-9-28 20:40:00 | 显示全部楼层
那怎样用VB调出自己编写的屏幕菜单?能否指点一下,谢谢!
GMT+8, 2025-5-5 04:05 , Processed in 0.156528 second(s), 23 queries , Gzip On.
