程序如下:(包括两个程序:LPLACE.LISP 和 UNDO.LISP)
LPLACE.LISP
(defun lplace(/ m n insblk insang inspt olyr)
(if (and (not undo_init) (equal -1 (load "undo.lsp" -1))) (progn (alert "Error:\n Cannot find UNDO.LSP.") (exit)) );if (err_init '("CMDECHO" "OSMODE" "BLIPMODE" "REGENMODE") T '(setq l_s nil)) (var_set '(("CMDECHO" 0) ("OSMODE" 0) ("BLIPMODE" 0) ("REGENMODE" 0)))
;; Get information (cond ((numberp light_scale)) (T (setq light_scale 1))) (cond (light_layer) (T (setq light_layer (getvar "CLAYER")))) (prompt (strcat "\n默认图层:\"" light_layer "\"。" )) (prompt (strcat "\n默认比例:\"" (rtos light_scale 2 2) "\"。")) (cond ((= (cdar (laychk light_layer)) "No") (laychk (setq light_layer (getvar "CLAYER"))) (prompt (strcat "\n图层被设为当前层:\"" light_layer "\"。" )) ) ); cond (while (not insblk) (initget "Layer Scale Name") (setq insblk (getkword "\n图层 L / 比例 S / 图块名 N:")) (cond ((= "Scale" insblk) (initget 6) (setq light_scale (cond ((getreal (strcat "\n请输入图块比例:<" (rtos light_scale 2 2) "> "))) (T light_scale) ); cond insblk nil ); setq ) ((= "Layer" insblk) (setq olyr light_layer insblk nil) (setq light_layer (getstring (strcat "\n请选择图层:<" light_layer "> "))) (cond ((= light_layer "") (setq light_layer olyr))) (cond ((= (cdar (laychk light_layer )) "No") (setq light_layer olyr) (prompt (strcat "\n图层仍为:\"" light_layer "\"。" ))) ); cond ) (T (cond ((= (getvar "INSNAME") "") (setq insblk (getstring "\n请输入图块名:")) (cond ((tblsearch "BLOCK" insblk) (setvar "INSNAME" insblk)) (T (setq insblk nil))); cond ) (T (setq insblk (getstring (strcat "\n请输入图块名:<" (getvar "INSNAME") "> "))) (cond ((= insblk "") (setq insblk (getvar "INSNAME")))); cond (cond ((tblsearch "BLOCK" insblk) (setvar "INSNAME" insblk)) (T (setq insblk nil))); cond ) ); cond (cond (insblk) (T (prompt "\n无效的图块!"))); cond ) ); cond ); while (setq insang (getangle "\n请输入图块的角度:<0> ")) (cond ((not insang) (setq insang 0))) (setq inspt (gettrs)) (setq n 0) (while (< n (length inspt)) (setq m 0) (while (< m (length (car inspt))) (apply '(lambda (iname ilayer ipoint iscale iangle) (entmake (list (cons 0 "INSERT") (cons 2 iname) (cons 8 ilayer) (cons 10 ipoint) (cons 41 iscale) (cons 42 iscale) (cons 43 iscale) (cons 50 iangle) ) ); entmake ); lambda (list insblk light_layer (nth m (nth n inspt)) light_scale insang) ); apply (setq m (1+ m)) ); while (setq n (1+ n)) ); while (initget 1 "Yes No") (cond ((= "Yes" (getkword "\n是否需要连线 ?(Y/N) ")) (connect insblk insang light_scale inspt)) ); cond
(layres) (err_restore) (princ) ); defun lplace
(defun gettrs(/ ulpt lrpt row col inspt deltax deltay n) (initget 1) (setq ulpt (getpoint "\n请选择右上角:")) (initget 1) (setq lrpt (getcorner ulpt "\n请选择左下角:")) (grdraw ulpt (list (nth 0 lrpt) (nth 1 ulpt)) 2 1) (grdraw (list (nth 0 lrpt) (nth 1 ulpt)) lrpt 2 1) (grdraw lrpt (list (nth 0 ulpt) (nth 1 lrpt)) 2 1) (grdraw (list (nth 0 ulpt) (nth 1 lrpt)) ulpt 2 1)
(initget 7) (setq row (getint "\n请输入行数:")) (initget 7) (setq col (getint "\n请输入列数:")) (setq deltax (/ (- (car lrpt) (car ulpt)) col) deltay (/ (- (cadr ulpt) (cadr lrpt)) row) ); setq
;; Try to find the transformer of points (repeat col ; new_first_row = (cons ((old_point) - deltax) old_first_row (cond (inspt ((lambda (x) (setq inspt (subst (cons (list (- (nth 0 (car x)) deltax) (nth 1 (car x)) (nth 2 (car x))) x) x inspt)) ); lambda (car inspt)) ) (T (setq inspt (list (list (list (- (nth 0 lrpt) (/ deltax 2.0)) (- (nth 1 ulpt) (/ deltay 2.0)) (nth 2 ulpt))))); setq ) ); cond (setq n 0) (while (< n (1- row)) ; new_row_information = (cons new_list old_row_information) ; or (subst new_row_information old_row_information) ; new_list = (car old_row_information) - deltay (apply '(lambda (x y) (cond ( y (setq inspt (subst (cons (list (nth 0 (car x)) (- (nth 1 (car x)) deltay) (nth 2 (car x))) y) y inspt)) ) (T (setq inspt (append inspt (list (cons (list (nth 0 (car x)) (- (nth 1 (car x)) deltay) (nth 2 (car x)) ) y)))) ) ); cond ); lambda (list (nth n inspt) (nth (1+ n) inspt)) ) (setq n (1+ n)) ); while ); repeat inspt ); defun gettrs
(defun turntrs(otrs / ntrs m n) (setq n 0) (while (< n (length otrs)) ((lambda (x) (setq m (1- (length x))) (while (>= m 0) (cond (ntrs ((lambda (y) (if y (setq ntrs (subst (cons (nth m x) y) y ntrs)) (setq ntrs (append ntrs (list (cons (nth m x) y)))) ); if ); lambda (nth (- (length x) m 1) ntrs) ; new row information ) ) (T (setq ntrs (list (list (nth m x))))) ); cond (setq m (1- m)) ); while ); lambda (nth n otrs) ) (setq n (1+ n)) ); while ntrs ); defun turntrs
(defun connect(insblk insang inscale inspt / fp blkinf flag temp ppair hor m n offset ) ; fetch available information of blocks ((lambda (f) (cond (f (setq fp (open f "r") temp (read-line fp)) (while (and temp (not blkinf)) ((lambda(x) (if (and (listp x) x) (if (= (strcase (cdr (assoc 0 x))) (strcase insblk)) (setq blkinf x)) ); if ); lambda (read temp) ) (setq temp (read-line fp)) ); while (close fp) ) (T (alert "无法打开文件 \"LIGHT.INI\" !")) ); cond ); lambda (findfile "LIGHT.INI") ) (cond (blkinf (cond (wire_layer) (T (setq wire_layer (getvar "CLAYER")))) (prompt (strcat "\n默认图层:\"" wire_layer "\"。" )) (cond ((= (cdar (laychk wire_layer)) "No") (laychk (setq wire_layer (getvar "CLAYER"))) (prompt (strcat "\n图层被设为当前层:\"" wire_layer "\"。" )) ) ); cond (while (not flag) (initget 1 "Layer Hor Ver") (setq flag (getkword "\n图层 L / 垂直 V / 水平 H:")) (cond ((= "Layer" flag) (setq temp wire_layer flag nil) (setq wire_layer (getstring (strcat "\n请选择图层:<" wire_layer "> "))) (cond ((= wire_layer "") (setq wire_layer temp))) (cond ((= (cdar (laychk wire_layer )) "No") (setq wire_layer temp) (prompt (strcat "\n图层仍为:\"" wire_layer "\"。" )) ) ); cond ) ((= "Hor" flag) (setq hor T)) ((= "Ver" flag) (setq inspt (turntrs inspt)) (setq hor nil)) ); cond ); while (setq offset '(1 2 3 4)) (repeat (fix (+ (/ (* insang 2) pi) 0.1)) ; Ajust offset according (setq offset (reverse (cdr (reverse (cons (last offset) offset))))) ; to angle ); repeat
(setq offset (mapcar '(lambda (x) (cdr (assoc x blkinf)) ); lambda (cond (hor (list (nth 0 offset) (nth 2 offset))) (T (list (nth 1 offset) (nth 3 offset)))) ; cond ); mapcar ); setq (setq offset (list (* inscale (nth 0 offset)) (* -1 inscale (nth 1 offset)))) ((lambda (y) (cond (hor (setq m 0)) (T (setq m 1))); cond (cond ((> (nth m (nth 0 y)) (nth m (nth 1 y))) (setq offset (mapcar '(lambda (x) (* -1.0 x) ); lambda offset ); mapcar ); setq ) ); cond ); lambda (car inspt)) (mapcar '(lambda (x) (setq m 0) (while (< m (1- (length x))) (setq ppair (mapcar '(lambda (x dx) (cond (hor (list (+ (nth 0 x) dx) (nth 1 x) (nth 2 x))) (T (list (nth 0 x) (+ (nth 1 x) dx) (nth 2 x))) ); cond ); lambda (list (nth m x) (nth (1+ m) x)) offset ); mapcar ); setq (apply '(lambda (llayer spoint epoint) (entmake (list (cons 0 "LINE") (cons 8 llayer) (cons 10 spoint) (cons 11 epoint) ) ); entmake ); lambda (list wire_layer (car ppair) (cadr ppair)) ); apply (setq m (1+ m)) ); while ); lambda inspt ); mapcar ) (T (alert "该图块未被正确配置!")) ); cond ); defun connect
(defun c:lp() (lplace)) (defun c:lplace() (lplace))
UNDO.LISP
(defun mod_att(ent id dxf_item) (while (and (/= "ATTRIB" (car (entgetf '(0) ent))) (/= id (car (entgetf '(2) ent)))) (setq ent (entnext ent)) ); while ((lambda (x) (mapcar '(lambda (y) (setq x (subst y (assoc (car y) x) x)) ); lambda dxf_item ); mapcar (entmod x) (entupd ent) ); lambda (entget ent) ) ); defun mod_att
;---------------------------------------------------------------------------- ; Check layer status, return a association list which contains layer information ;---------------------------------------------------------------------------- (defun laychk(lay / l_sta) ( (lambda (x) (if (not l_s) (setq l_s (list (cons x (logand 5 (cdr (assoc 70 (tblsearch "LAYER" x))))))) ); if ); lambda (getvar "CLAYER") ) (if (not (tblsearch "LAYER" lay)) (progn (initget "Yes No") (if (= (setq l_sta (getkword "\n图层不存在,是否建立该图层 ?\(Y/N\)")) "Yes") (progn (command "_.layer" "n" lay "") (setq l_sta 0) ); progn ); if ); progn (progn (setq l_sta (logand 5 (cdr (assoc 70 (tblsearch "LAYER" lay))))) (if (= 1 (logand 1 l_sta)) (progn (initget "Yes No") (if (= (getkword "\n该图层被冻结,是否解冻 ?\(Y/N\)") "Yes") (command "_.layer" "t" lay "") (setq l_sta "No") ); if ); progn ); if (if (numberp l_sta) (if (= 4 (logand 4 l_sta)) (command "_.layer" "u" lay "")); if ); if ); progn ); if ( (lambda (x) (cond ( (not x) (setq l_s (cons (cons lay l_sta) l_s)) ) ( (= "No" (cdr x)) (setq l_s (subst (cons lay l_sta) x l_s)) ) ( T l_s) ); cond ); lambda (assoc lay l_s) )
); defun chklay
;---------------------------------------------------------------------------- ; Restore layer status according to association list l_s ;---------------------------------------------------------------------------- (defun layres() (setvar "CLAYER" (car (last l_s))) (repeat (length l_s) ( (lambda(x) (if (numberp (cdr x)) (progn (if (= 4 (logand 4 (cdr x))) (command "_.layer" "lo" (car x) "") ); if (if (= 1 (logand 1 (cdr x))) (command "_.layer" "f" (car x) "") ); if ); progn ); if ); lambda (car l_s) ) (setq l_s (cdr l_s)) ); repeat ); layres
;---------------------------------------------------------------------------- ; Get DXF codes ;---------------------------------------------------------------------------- (defun entgetf (index ent) ((lambda (e) (mapcar '(lambda (x) (cdr (assoc x e)) ); lambda index) ; internal lambda function ); lambda (entget ent) ) ); defun entgetf
;---------------------------------------------------------------------------- ; Save UNDO status ;---------------------------------------------------------------------------- (defun undo_init (/ cmdecho undo_ctl) (setq cmdecho (getvar "CMDECHO") undo_ctl (getvar "UNDOCTL")) ; Save the value (setvar "CMDECHO" 0)
(if (equal 0 undo_ctl) ; Make sure undo is fully enable (command "_.undo" "_all") (command "_.undo" "_control" "_all") )
(if (equal 4 (logand 4 (getvar "UNDOCTL"))) ; Ensure undo auto is off (command "_.undo" "_auto" "_off") )
(while (equal 8 (logand 8 (getvar "UNDOCTL"))) ; Place an end mark here (command "_.undo" "_end") )
(while (not (equal 8 (logand 8 (getvar "UNDOCTL")))) (command "_.undo" "_group") )
(setvar "CMDECHO" cmdecho) undo_ctl ); defun undo_init
;---------------------------------------------------------------------------- ; Restore UNDO status ;---------------------------------------------------------------------------- (defun undo_restore (/ cmdecho) (if old_undoctl (progn (setq cmdecho (getvar "CMDECHO")) (setvar "CMDECHO" 0)
(if (equal 0 (getvar "UNDOCTL")) (command "_.undo" "_all")) (while (equal 8 (logand 8 (getvar "UNDOCTL"))) (command "_.undo" "_end") ); while
(if (not (equal old_undoctl (getvar "UNDOCTL"))) (progn (cond ((equal 0 old_undoctl) (command "_.undo" "_control" "_none") ) ((equal 2 (logand 2 old_undoctl)) (command "_.undo" "_control" "_one") ) ) (if (equal 4 (logand 4 old_undoctl)) (command "_.undo" "_auto" "_on") (command "_.undo" "_auto" "_off") ) ) ) (setq old_undoctl nil) (setvar "CMDECHO" cmdecho) ) ) ); defun undo_restore
;---------------------------------------------------------------------------- ; Save variables ;---------------------------------------------------------------------------- (defun var_save (a) (setq m_lst '()) (repeat (length a) (setq m_lst (append m_lst (list (list (car a) (getvar (car a)))))) (setq a (cdr a)) ) ); defun var_save
;---------------------------------------------------------------------------- ; Set variables ;---------------------------------------------------------------------------- (defun var_set (m_lst) (repeat (length m_lst) (setvar (caar m_lst) (cadar m_lst)) (setq m_lst (cdr m_lst)) ) ); defun var_set
;---------------------------------------------------------------------------- ; Restore variables ;---------------------------------------------------------------------------- (defun var_restore () (repeat (length m_lst) (setvar (caar m_lst) (cadar m_lst)) (setq m_lst (cdr m_lst)) ) ); defun var_restore
;---------------------------------------------------------------------------- ; Initialize routine ;---------------------------------------------------------------------------- (defun err_init(e_lst u_enable add_fun) (if err_alive (err_restore)) ; To avoid nested call (setq err_alive T) (var_save e_lst) ; Save the modes (if u_enable (setq old_undoctl (undo_init))) ; Initialize UNDO status (setq err_old *error* *error* err_main) ; Save the handle of *error* (if add_fun ; Add the user cleaner (setq *error* (append (reverse (cdr (reverse *error*))) (list add_fun (last *error*)) ); append ) ) ); defun err_init
;---------------------------------------------------------------------------- ; Error routine body ;---------------------------------------------------------------------------- (defun err_main( msg / ) ; Body of error routine (if (/= msg "Function cancelled") ;If an error (such as CTRL-C) occurs (princ (strcat "\nError: " s)) ;while this command is active... ) (while (not (equal (getvar "CMDNAMES") "")) (command nil)) ; Get out of any active command
(if old_undoctl (progn (while (not (wcmatch (getvar "CMDNAMES") "*UNDO*")) ; See (command "_.undo") ; if it's in UNOD command ) (command "_end") (command "_.undo" "1") (while (not (equal (getvar "CMDNAMES") "")) (command nil)) (undo_restore) ; Restore the status of UNDO ) )
(var_restore) ; Restore the variables (if err_old (setq *error* err_old err_old nil)) ; Restore the handle of error (setq err_alive nil) (princ) ); defun err_main
;---------------------------------------------------------------------------- ; Restore error status ;---------------------------------------------------------------------------- (defun err_restore() (undo_restore) ; Restore the status of UNDO (var_restore) ; Restore the variables (if err_old (setq *error* err_old err_old nil)) ; Restore the handle of error (setq err_alive nil) (princ) ); defun err_restore |
