查看: 1959|回复: 3
如何修改选择集中对象的属性
发表于 2005-9-6 16:04:00 | 显示全部楼层 |阅读模式
我想先将选择集中的对象复制 然后再将其图案名改成别的图案,怎么也试验不成功请高手指点! 谢谢
Dim acadDoc As AcadDocument
Private Sub Command1_Click()
On Error Resume Next
Set acadApp = GetObject(, "AutoCAD.Application")
If Err Then
Err.Clear
Set acadApp = CreateObject("AutoCAD.Application")
If Err Then End
End If
acadApp.Visible = True
Set acadDoc = acadApp.ActiveDocument
Dim ssetObj As AcadSelectionSet
 K = -1
 For i = 0 To acadDoc.SelectionSets.Count - 1
 If acadDoc.SelectionSets.Item(i).Name = "SSET" Then acadDoc.SelectionSets.Item(i).Delete
  Next i
  Set ssetObj = acadDoc.SelectionSets.Add("SSET")
  Dim corner1(0 To 2) As Double
  Dim corner2(0 To 2) As Double
    corner1(0) = 0: corner1(1) = 0: corner1(2) = 0
    corner2(0) = 200: corner2(1) = 200: corner2(2) = 0
    Dim gpCode(0) As Integer
    Dim dataValue(0) As Variant
    gpCode(0) = 0
    dataValue(0) = "HATCH"
   ' gpCode(1) = 2
   ' dataValue(1) = "SOLID"
    Dim groupCode As Variant, dataCode As Variant
    groupCode = gpCode
    dataCode = dataValue
    ssetObj.Select acSelectionSetAll, , , groupCode, dataCode
  For i = 0 To ssetObj.Count - 1
   ssetObj.Item(i).Move corner1, corner2
  Next i
End Sub
发表于 2005-9-6 20:03:00 | 显示全部楼层
复制用Copy函数
 楼主| 发表于 2005-9-7 08:20:00 | 显示全部楼层
经过研究能考贝了,只能改变颜色,但不能修改图案名 代码如下
Dim acadApp As AcadApplication
If Err Then
Err.Clear
If Err Then End
End If
Dim COPYObj As AcadEntity
Dim ss As Object
Dim s1, s2 As AcadHatch
Dim acad_obj As AcadObject
 K = -1
  Next i
    gpCode(0) = 0
   ' gpCode(1) = 2
    groupCode = gpCode
     ssetObj.Clear
 Set s1 = ssetObj.Item(0)
 Set s2 = s1.Copy
 ssetObj.Item(0).Move corner1, corner2
 s1.Color = 2
 s2.Color = 1
 MsgBox s2.PatternName
 s2.PatternName = "asni32" '这儿就出错了 说是只读
 ssetObj.Clear
End Sub
发表于 2008-2-1 14:46:00 | 显示全部楼层
'图案名改成别的图案
hatchObj.SetPattern acHatchPatternTypePreDefined, "BRICK"
GMT+8, 2025-2-21 03:19 , Processed in 0.142352 second(s), 23 queries , Gzip On.
