查看: 1592|回复: 1
求助:为什么看不到创建的块??
发表于 2005-9-9 16:31:00 | 显示全部楼层 |阅读模式
求助:为什么看不到创建的块??
          程序如下:
Sub Example_Add()
    ' 创建一新块,名称为"New_Block"
    Dim blockObj As AcadBlock
    ' 定义块
    Dim insertionPnt(0 To 2) As Double
    insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0#
    ' 添加块到块集合中
    Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "*N")
    MsgBox blockObj.Name & " has been added." & vbCrLf & _
            "Origin: " & blockObj.Origin(0) & ", " & blockObj.Origin(1) _
            & ", " & blockObj.Origin(2), , "Add Example"
    ' 在块中创建圆.
    Dim circleObj As AcadCircle
    Dim centerPoint(0 To 2) As Double
    Dim radius As Double
    ' 定义圆
    centerPoint(0) = 0#: centerPoint(1) = 0#: centerPoint(2) = 0#
    radius = 100#
    ' 添加圆到块中
    Set circleObj = blockObj.AddCircle(centerPoint, radius)
    Set blockObj = Nothing
End Sub
  请指教
发表于 2005-9-9 20:43:00 | 显示全部楼层
还没有插入呢,那是一个无名块
GMT+8, 2025-5-5 01:44 , Processed in 0.223688 second(s), 23 queries , Gzip On.
