查看: 2397|回复: 2
标注公差的程序(LISP)
发表于 2005-9-10 12:14:00 | 显示全部楼层 |阅读模式
  我在请教各位高手一个问题,下面程序也是我在网上下载的,但这个程序有一个缺点,就是当上偏差或下偏差中有一个数为"0"时,0就和"+"或"-'对起,这不符合国标,我改了一下程序,在上面加了几条代码:
  ( if (=  ltoll+ 0)
  (setq ltola (strcat "{\\H0.6x;\\S " ltoll+ "^"ltoll-";}")))
   (if (= ( ltoll- 0)
   (setq ltola (strcat "{\\H0.6x;\\S" ltoll+ "^ "ltoll-";}")))
   (if  (and (/= ltoll+ 0) (/= ltoll+ 0))  (setq ltola (strcat "{\\H0.6x;\\S" ltoll+ "^" ltoll-";}")))
但好象函数没判断,不管上下偏差有否为零,它都执行(setq ltola (strcat "{\\H0.6x;\\S" ltoll+ "^" ltoll-";}"))),请问那位高手能帮我看一下,错在那里,谢谢!
原程序:
(defun c:gc (/ ++++ ---- ltoll+ ltoll-   ltola ltolb diment ENT dimtext
                   ldimdata rr ltoltext1 ccc pr01 ltoltext2 ddd pr02 crackl)
  (setvar "cmdecho" 0)
  (if (null ltoldata+)(setq ltoldata+ "0.1"))
  (if (null ltoldata-)(setq ltoldata- "0.1"))
  (setq ++++ (strcat "\n输入上公差" "<" ltoldata+ ">" ":"))
  (initget 128)(setq ltoll+ (getkword ++++))(if (null ltoll+)(setq ltoll+ ltoldata+))
  (setq ---- (strcat "\n输入下公差" "<" ltoldata- ">" ":"))
  (initget 128)(setq ltoll- (getkword ----))(if (null ltoll-)(setq ltoll- ltoldata-))
  (if (= ltoll+ ltoll-)(setq ltolb (strcat "%%P" ltoll+)))
  (setq ltoldata+ ltoll+);;保存本次输入正公差数值
  (setq ltoldata- ltoll-);;保存本次输入负公差数值
  ;;选择开始
  (SETQ diment (ENTSEL "\n选择应用公差的尺寸 : "));;选择物件
  (if (null diment)(exit (PRINC "\n错误! 没有选择任何物件!")));;判断是否为有效选取
  (SETQ ENT (ENTGET (CAR diment)));;取得选择的资料串行
  (setq dimtext (CDR (ASSOC 0 ENT)));;取得资料串行名称,判断选择的物件是否为尺寸
  (if (/= dimtext "DIMENSION")(exit (princ "\n错误! 选择的物件非尺寸或尺寸已分解!")))
  (setq ldimdata (CDR (ASSOC 1 ENT)));;取得尺寸资料串行
  (setq rr (substr ldimdata 1 2));;抽取尺寸值前2位
  (if (or (= rr "") (= rr "<>"))
    (setq ltoltext1 (strcat "<>" ltola))
    (setq ccc(subst (cons 1 ltoltext1)(assoc 1 ENT)ENT))
    (entmod ccc);;(entupd diml1)
      (if (or (/= rr "") (/= rr "<>"))(exit (princ "\n错误! 尺寸被修改过! 只支持实际数值及未分解的尺寸!")))
  (if (= ltoldata+ ltoldata-)
    (setq ltoltext2 (strcat "<>" ltolb))
    (setq ddd(subst (cons 1 ltoltext2)(assoc 1 ENT)ENT))
    (entmod ddd)
      (setq crackl 2006)
  (princ (strcat "\nOK! 恭喜你成功标注公差!"))
改过后的程序:
   ( if (=  ltoll+ 0)
    (if (= ( ltoll- 0)
  ;;选择开始
    (entmod ddd)
      (setq crackl 2006)
发表于 2005-9-11 22:06:00 | 显示全部楼层
1、判断有问题:(=  ltoll+ 0)应为(=  ltoll+ "0");
(and (/= ltoll+ 0) (/= ltoll+ 0))应为(and (/= ltoll+ "0") (/= ltoll+ "0"))。
2、多括弧:(if (= ( ltoll- 0)应为(if (= ltoll- "0")。
发表于 2012-10-10 13:19:14 | 显示全部楼层
下公差等于0时,代码里的那个空格怎么不管用呀
GMT+8, 2025-8-28 00:21 , Processed in 0.179636 second(s), 25 queries , Gzip On.
