查看: 1313|回复: 0
请赐教,不胜感激。
发表于 2003-1-6 11:42:00 | 显示全部楼层 |阅读模式
请赐教,不胜感激。看了cad帮助文件就大胆想写来试试,可是不知怎么给
两个按钮分配动作来分别交替显示两幅幻灯片。
(defun c:sw ( / dcl_id )
    (setq dcl_id (load_dialog "sw"))
    (if (not (new_dialog "sw" dcl_id))(exit))
    (setq x (dimx_tile "show tit")
          y (dimy_tile "show tit"))
    (start_image "show tit")
    (slide_image 0 0 x y "a2")
    (end_image)
    (start_dialog)
    (unload_dialog dcl_id)
// =========show_htit.lsp===选择htit单选钮的作========
(defun show_htit ( / dcl_id )
    (end_image)
  (start_dialog)
// =========show_vtit.lsp===选择vtit单选钮的作=========
(defun show_vtit ( / dcl_id )
    (slide_image 0 0 x y "b2")
    (end_image)
  (start_dialog)
// =========sw.dcl=对话框================================
sw : dialog {
    label = "横竖图框";
    : boxed_column {
        label = "图框";
        : image {
                key = "show tit";
                height = 12;
                width = 10;
                color = -2;
        : radio_row {
                key = "htit_vtit";
                : radio_button {
                     label = "横图&H";
                     key = "htit";
                     value = "1";
                : radio_button {
                     label = "竖图&V";
                     key = "vtit" ;
                     value = "0";
    ok_cancel_help;
GMT+8, 2025-5-20 13:30 , Processed in 0.137421 second(s), 23 queries , Gzip On.
