- (load "xyp_lib")
- ;|加载通用函数(可在签名栏直接下载)
- 如果已经下载xyp_lib并放到搜索路径下可以不再下载!
- 利用以下任何一种方式即可加载和运行通用函数内的所有子程序:
- 1.在acad.lsp中增加(load"xyp_lib")
- 2.在每个程序内增加(load"xyp_lib")
- 3.在command下,输入(load"xyp_lib")
- 4.在菜单.mnl中增加(load"xyp_lib")
- 5.将xyp_lib.vlx文件直接拽到cad屏幕
- [COLOR=red] ★通用函数下载地址:[/COLOR]
- [url]http://www.xdcad.net/forum/attachment.php?s=&postid=1606661[/url]
- [url]dispbbs.asp?boardID=3&ID=37554&page=1[/url]|;
- ;;;标注多义线各段线长
- (defun c:test ()
- (CMDLASC0)
- (setq ss (ssget '((0 . "*LINE")))
- i -1
- (mkla "线长标注" 4)
- (while (setq s1 (ssname ss (setq i (1+ i))))
- (setq ptlst (uptlst s1))
- (while (setq pt1 (car ptlst))
- (if (setq ptlst (cdr ptlst))
- (progn
- (setq pt2 (car ptlst)
- tx (rtos (distance pt1 pt2) 2 2)
- ang (rad2ang (angle pt1 pt2))
- pt-tx (PT-RIGHT pt1 pt2 (* sc 100))
- (command "text" "j" "BC" pt-tx (* sc 300) ang tx)
- (CMDLA1)
程序效果:
