以下是我的程序,请大侠帮忙看看
我用的格式是这样的数字的两边有"<" 和 ">"
我编的程序是改例如这样的数字的 :<1>
;;;子程序 (defun c:gf() (setq shu (getint "\n 请输入步长:")) )
(defun c:jia() (setq ent (car (entsel "\n 请选择被复制的数字:"))) (redraw ent 3) (setq djq (entget ent)) (setq txtzh (assoc 1 djq)) (setq txth (cdr txtzh))
(setq len (strlen txth)) (setq txt (substr txth 2 (- len 1)))
(setq a (atoi txt))
(setq pt1 (getpoint "\n 请选择一个点:")) (setq pt2 (getpoint pt1 "\n 请选择第二点:")) (setq n 0) (while pt2
(setq b (+ shu a n)) (setq c (itoa b))
(setq d (strcat "<" c ">"))
(setq e (cons 1 d)) (command "copy" ent "" pt1 pt2) (setq ent1 (entget (entlast))) (setq txtzh1 (assoc 1 ent1)) (setq ent1 (subst e txtzh1 ent1)) (entmod ent1)
(princ) (setq n (+ shu n)) (setq pt2 (getpoint "\n 请选择第二点:"))
