查看: 3385|回复: 6
如何批量剪切过圆或矩形的线;只剪圆和矩形内的线
发表于 2005-9-24 14:33:00 | 显示全部楼层 |阅读模式
发表于 2005-9-24 15:38:00 | 显示全部楼层
你这里的线只是指直线(Line)吗?
 楼主| 发表于 2005-9-24 16:02:00 | 显示全部楼层
想LINE和PLINE都可
发表于 2005-10-9 14:22:00 | 显示全部楼层
我想编一个局部放大的程序,跟这个也是有关系的,思路应该是一样的。
这是一个剪内圆的程式,请大家指教!
(defun c:t1 (/ loop en ss i sn snType)
  (princ "\nPlease select a Circle:")
  (vl-load-com)
  (setq *AcadDocument* (vla-Get-ActiveDocument (vlax-get-acad-object)))
  (setq loop t)
  (while (not (setq en (ssget ":s" '((0 . "circle"))))) (princ "\nPlease select a circle"))
  (setq en (ssname en 0))
  (vla-StartUndoMark *AcadDocument*)
  (vla-GetBoundingBox (vlax-ename->vla-object en) 'MinPt 'MaxPt)
  (setq ss (ssget "_c" (vlax-safearray->list MaxPt) (vlax-safearray->list MinPt)))
  (setq i 0)
  (repeat (sslength ss)
    (setq sn (ssname ss i))
    (setq snType (vla-Get-ObjectName (vlax-ename->vla-object sn)))
    (if (not (member snType '("AcDbBlock" "AcDbText" "AcDbMText" "AcDbDimension" "AcDbXline" "AcDbRay")))
      (trim sn en)
    (setq i (1+ i))
  (vla-EndUndoMark *AcadDocument*)
  (prin1)
(defun trim (sn en / vs vn pts Err lstParam pts lstPt)
  (setq vs (vlax-ename->vla-object sn)
 vn (vlax-ename->vla-object en)
  (setq pts (vla-intersectwith vn vs acExtendNone))
  (setq Err (vl-catch-all-apply 'vlax-safearray->list (list (vlax-variant-value pts))))
  (if (not (vl-catch-all-error-p Err)) ;安璝Τ岿⊿Τユ翴玥ぃ暗安璝Τユ翴玥trim奔;
;;;      (alert "InterSectWith")
      (setq lstParam '()
     lstParam (append lstParam (list (vlax-curve-getStartParam vs)))
     lstParam (append lstParam (list (vlax-curve-getEndParam vs)))
      (setq pts      (vlax-safearray->list (vlax-variant-value pts))
     lstParam (GetParams pts lstParam vs)
     lstParam (vl-sort lstParam '<)
      (setq lstPt (GetPtFromParam lstParam vs))
      (foreach pt lstPt
 (if (< (distance pt (vlax-safearray->list (vlax-variant-value (vla-get-center vn))))
        (vla-Get-Radius vn)
   (command ".trim" en "" pt "")
(defun GetParams (pts lstParam vs / num i pt)
  (setq num (/ (length pts) 3)
 i   0
  (repeat num
    (setq pt    (list (nth (+ i 0) pts) (nth (+ i 1) pts) (nth (+ i 2) pts))
   lstParam (append lstParam (list (vlax-curve-getParamAtPoint vs pt)))
   i    (+ i 3)
  lstParam
(defun GetPtFromParam (lstParam vs / lst i num p1 p2 pm)
  (setq lst '()
 i   0
 num (1- (length lstParam))
  (repeat num
    (setq p1  (nth i lstParam)
   p2  (nth (1+ i) lstParam)
   pm  (/ (+ p1 p2) 2)
   pt  (vlax-curve-GetPointAtParam vs pm)
   lst (append lst (list pt))
   i   (1+ i)
  lst
发表于 2005-10-9 15:21:00 | 显示全部楼层
多往后看几页帖子吧,我以前见过类似的帖子,里面有解决的程序.
发表于 2005-10-12 07:39:00 | 显示全部楼层
tc405003发表于2005-9-24 14:33:00回复:(tc405003)如何批量剪切过圆或矩形的线;只剪圆和矩形内的线如何批量剪切过圆或矩形的线;只剪圆和矩形内的线
可以研究一下ET的命令:extrim
发表于 2010-10-11 18:37:00 | 显示全部楼层
谢谢楼上的分享,参考下,很感激
GMT+8, 2025-2-23 19:37 , Processed in 0.196172 second(s), 25 queries , Gzip On.
