(defun c:tcc ( / e0 l n s1 xzjtxt) (CMDLA0) (command "color" "bylayer") (setq wenzhi (getstring "\n请输入想要修改的文字:<可部分文字>")) (MKLA "tangchao" 2) (if (setq s1 (ssget "x" '((0 . "TEXT")))) (progn (setq l 0 n (sslength s1) xzjtxt (ssadd)) (while (< l n) (setq e (ssname s1 l)) (setq eb (entget e)) ;(REPEAT (sslength s1)
(if (or (and (= "TEXT" (cdr (assoc 0 eb))) (wcmatch (cdr (assoc 1 eb)) "*"wenzhi"*"))) ;(if (setq s1 (ssget "x" (LIST(CONS 0 "TEXT") (CONS 1 (STRCAT "*"wenzhi"*"))))) (ssadd (ssname s1 l) xzjtxt) ) (setq l (1+ l)) ) (if (< 0(sslength xzjtxt)) (progn (command "change" xzjtxt "" "p" "la" name "") (COMMAND "CHPROP" xzjtxt "" "C" "BYLAYER" "") (princ "\n程序提示:修改完成.")) ) (princ "\n程序提示: 没有找到要修改的图元.") ) ) (CMDLA1) (princ) ) |
