查看: 3813|回复: 10
关于惯性矩计算cad2002中运行正常,2004/5/6中运行出错
发表于 2005-9-29 15:13:00 | 显示全部楼层 |阅读模式
关于惯性矩计算cad2002中运行正常,2004/5/6中运行出错,代码为
Private Sub CommandButton_Click()
UserForm1.Hide
Dim temp(0 To 2) As Double
Dim currUCS As AcadUCS
Dim origin(0 To 2) As Double
Dim Centroid As Variant
Dim momentOflnertia As Variant
Dim sset As AcadSelectionSet 'Define sset as a SelectionSet object
'Set sset to a new selection set namaed SS1 (the name doesn't matter here)
Set sset = ThisDrawing.SelectionSets.Add("SS1")
sset.SelectOnScreen 'Prompt user to selet objects
'save cuurent UCS origin
temp(0) = ThisDrawing.ActiveUCS.origin(0)
temp(1) = ThisDrawing.ActiveUCS.origin(1)
temp(2) = ThisDrawing.ActiveUCS.origin(2)
Dim ent As Object 'Define ent as an object For Each ent In sset
'Loop throught the SelectionSet collection
If ent.EntityName = "AcDbRegion" Then
Centroid = ent.Centroid
'Create a UCS and makes it current
Set currUCS = ThisDrawing.ActiveUCS
origin(0) = Centroid(0): origin(1) = Centroid(1): origin(2) = 0
currUCS.origin = origin
ThisDrawing.ActiveUCS = currUCS
momentOflnertia = ent.momentOflnertia
MsgBox "lx=" & Format(momentOflnetia(0) / 10000, "######.00") & "cm^4: ly=" & Format(momentOflnetia(1) / 10000, "######.00") & "cm^4", , "被选择物体的惯性矩"
currUCS.origin = temp
ThisDrawing.ActiveUCS = currUCS 'restore ActiveUCS origin
End If
Next ent
sset.Delete
UserForm1.Show
End Sub
Private Sub CommandButton2_Click()
Unload Me
End Sub
 楼主| 发表于 2005-9-29 15:18:00 | 显示全部楼层
第二次运行时出现另一行错误
发表于 2005-9-29 21:45:00 | 显示全部楼层
很多键入错误,主要是momentOfInertia错了
这段程序在2002也不运行正常,问问题应该说实话!
 楼主| 发表于 2005-9-30 09:41:00 | 显示全部楼层
alin发表于2005-9-29 21:45:00 很多键入错误,主要是momentOfInertia错了 这段程序在2002也不运行正常,问问题应该说实话!
请教alin,可以帮修正一下吗?
我在2002中运行好像没发现什么问题
发表于 2005-9-30 14:33:00 | 显示全部楼层
You should copy your codes in 2002 and paste it here. The spelling the word 'MomentOfInertia' is wrong in your code. It is "I" not "l". Please double check your code. Some "MomentOfInertia" miss an "r" in between.
BTW, try to delete the selection set named "SS1" first before going for another test. A selection set named "SS1" has been left in the drawing database when your routine breaks down. This will cause an error while you try to create another selection set with the same name.
 楼主| 发表于 2005-9-30 15:01:00 | 显示全部楼层
alin发表于2005-9-30 14:33:00 You should copy your codes in 2002 and paste it here. The spelling the word 'MomentOfInertia' is wrong in your code. It is \"I\" not...
复制代码后还是不行,请alin帮忙看看是什么问题,非常感谢!
Private Sub CommandButton1_Click()
    UserForm1.Hide
    Dim momentOfInertia As Variant
    'Set sset to a new selection set named SS1 (the name doesn't matter here)
    sset.SelectOnScreen                  'Prompt user to select objects
    'save current UCS origin
    For Each ent In sset                 'Loop through the SelectionSet collection
            ' Create a UCS and makes it current
            momentOfInertia = ent.momentOfInertia
            MsgBox "Ix=" & Format(momentOfInertia(0) / 10000, "######.00") & "cm^4:Iy=" & Format(momentOfInertia(1) / 10000, "######.00") & "cm^4", , "被选择物体的惯性矩"
            End If
    Next ent
    sset.Delete
    UserForm1.Show
End Sub
    Unload Me
End Sub
Private Sub Image1_Click()
End Sub
发表于 2005-9-30 15:09:00 | 显示全部楼层
Try to run UCS command and save an UCS first
 楼主| 发表于 2005-9-30 15:21:00 | 显示全部楼层
我把dvb文件传上来,alin能否帮看看?
发表于 2005-9-30 21:32:00 | 显示全部楼层
问题应该不在版本,是UCS的问题,凑合用着吧...
 楼主| 发表于 2005-10-1 10:49:00 | 显示全部楼层
alin发表于2005-9-30 21:32:00 问题应该不在版本,是UCS的问题,凑合用着吧... UploadFile/2005-9/200593021322234.rar,viewFile.asp?ID=21818
非常感谢!
GMT+8, 2025-5-2 21:02 , Processed in 0.157933 second(s), 24 queries , Gzip On.
