查看: 1773|回复: 4
[分享]能返回所有图层的表,从DDMODIFY中找出来的
发表于 2005-9-29 22:35:00 | 显示全部楼层 |阅读模式
 (defun make_lay_lists (/ layname sortlist name templist layer_number)
    (setq sortlist nil)
    (setq templist (tblnext "LAYER" T))
    (setq layer_number 1)
    (while templist
      ;; No xref dependent layers, please.
          (if (/= (logand 16 (cdr (assoc 70 templist))) 16)
              (setq name (cdr (assoc 2 templist)))
          (setq sortlist (cons name sortlist))
          ; Get the next layer.
      (setq templist (tblnext "LAYER"))
      ;; Not dead message...
      (if (= (/ layer_number 50.0) (fix (/ layer_number 50.0)))
        (set_tile "error" (strcat "Collecting..." (itoa layer_number)))
      (setq layer_number (1+ layer_number))
    (set_tile "error" "")
    (if (>= (getvar "maxsort") (length sortlist))
        (if (> layer_number 50)
          (set_tile "error" "Sorting...")
        (setq sortlist (acad_strlsort sortlist))
      (setq sortlist (reverse sortlist))
    (setq laynmlst sortlist)
发表于 2005-9-30 12:47:00 | 显示全部楼层
又是哪儿抄来的吧,改得乱七八糟的
发表于 2005-10-1 10:03:00 | 显示全部楼层
兄弟佩服,这也能找出来。呵呵:P
 楼主| 发表于 2005-10-1 11:40:00 | 显示全部楼层
呵呵,我一字未改啊,不信你查R14的DDMODIFY命令。
GMT+8, 2025-5-19 19:52 , Processed in 0.183301 second(s), 27 queries , Gzip On.
