(setvar "CMDECHO" 0) (defun V# (n e / pt_) (if (not (listp e)) (setq e (entget e))) (setq pt_ (cdr (assoc n e))) (if (and (> n 9) (< n 34) (/= pt_ nil) ) (trans pt_ 0 1) (setq pt_ pt_) ) ) ;去掉拟和 (defun c:a24( / sele sele1 e1 la n n0 ) (setq e1 (car (entsel "请选择一个线使所在层的线去掉拟和:"))) (setq la (v# 8 e1) type (v# 0 e1)) (setq sele (ssget "X" (list (cons 0 type) (cons 8 la)))) (setq n (if sele (sslength sele) 0)) (setq n0 0) (repeat n (setq e1 (ssname sele n0)) (command "pedit" e1 "s" "") (print n0) (setq n0 (+ n0 1)) ) ) |
