查看: 1677|回复: 5
[求助]
发表于 2005-10-2 06:04:00 | 显示全部楼层 |阅读模式
请教如何将2005的标题栏换成自己的标题栏?谢谢!
发表于 2005-10-2 11:37:00 | 显示全部楼层
reply
Public Declare Function SetWindowText Lib "user32" Alias "SetWindowTextA" (ByVal hwnd As Long, ByVal lpString As String) As Long
Public Declare Function GetParent Lib "user32" (ByVal hwnd As Long) As Long
Public Sub SetTitle(ByVal hwnd As Long, Optional ByVal title As String)
    If title = "" Then
        title = "明经通道 http://www.mjtd.com"
    End If
    SetWindowText hwnd, title
End Sub
Public Sub Test_SetTitle()
    Dim hwnd As Long    '&
    hwnd = GetParent(GetParent(ThisDrawing.hwnd))
    SetTitle hwnd, "Hello World!"
End Sub
 楼主| 发表于 2005-10-2 15:36:00 | 显示全部楼层
能否再具体一些,谢谢!
发表于 2005-10-3 12:43:00 | 显示全部楼层
这样还不具体?
发表于 2005-10-3 13:44:00 | 显示全部楼层
很具体了。另外请问一下,能不能通过命令行修改标题栏?
发表于 2005-10-5 14:42:00 | 显示全部楼层
mikewolf2k发表于2005-10-3 13:44:00很具体了。另外请问幌拢懿荒芡ü钚行薷谋晏饫福?lt;/DIV>
  1. (defun SetTitleBar (Str)
  2.   (setvar "USERS5" Str)
  3.   (vl-vbarun "h:/alin/SetTitleBar.dvb!Test_SetTitle")
  4.   (princ)
  5. )
  1. Public Declare Function SetWindowText Lib "user32" Alias "SetWindowTextA" (ByVal hwnd As Long, ByVal lpString As String) As Long
  2. Public Declare Function GetParent Lib "user32" (ByVal hwnd As Long) As Long
  1. Public Sub SetTitle(ByVal hwnd As Long, Optional ByVal title As String)
  2.     If title = "" Then
  3.         title = "???? http://www.mjtd.com"
  4.     End If
  5.     SetWindowText hwnd, title
  6. End Sub
  1. Public Sub Test_SetTitle()
  2.     Dim hwnd As Long    '&
  3.     hwnd = GetParent(GetParent(ThisDrawing.hwnd))
  4.     SetTitle hwnd, ThisDrawing.GetVariable("USERS5")
  5. End Sub
GMT+8, 2025-5-5 05:16 , Processed in 0.160836 second(s), 23 queries , Gzip On.
