如何使这个序号文字的程序在插入文字的时候能旋转角度
(vl-load-com) (setq *ACADDOC* (vla-get-activedocument (vlax-get-acad-object))) (defun SL-NUM2CHAR (INT / STR RES CHAR MBR) (while (/= (/ INT 26) 0) (setq RES (rem INT 26) INT (/ INT 26)) (if (= RES 0) (setq RES 26 INT (1- INT))) (setq CHAR (cons RES CHAR))) (if (/= INT 0) (setq CHAR (reverse (cons INT CHAR)))) (setq STR NIL) (foreach MBR CHAR (setq STR (cons (+ MBR 64) STR))) (setq STR (vl-list->string STR))) (defun SL-CHAR2NUM (STR / I INT) (setq I 0 STR (reverse (vl-string->list (strcase STR))) INT 0) (while (nth I STR) (setq INT (+ INT (* (- (nth I STR) 64) (expt 26 I))) I (1+ I))) (abs INT)) (defun TNJ-DCL-ON2 (/ ON) (setq *TNJ-ON2 (get_tile "DCL_ON2") ON (- 1 (atoi *TNJ-ON2))) (mode_tile "DCL_PF2" ON) (mode_tile "DCL_SN2" ON) (mode_tile "DCL_AN2" ON) (mode_tile "DCL_SF2" ON) (mode_tile "DCL_LM2" ON) (mode_tile "DCL_ON3" ON) (TNJ-DCL-ON3) (if (= ON 1) (progn (mode_tile "DCL_PF3" 1) (mode_tile "DCL_SN3" 1) (mode_tile "DCL_AN3" 1) (mode_tile "DCL_SF3" 1) (mode_tile "DCL_LM3" 1))) (TNJ-DCL-UP)) (defun TNJ-DCL-ON3 (/ ON) (setq *TNJ-ON3 (get_tile "DCL_ON3") ON (- 1 (atoi *TNJ-ON3))) (mode_tile "DCL_PF3" ON) (mode_tile "DCL_SN3" ON) (mode_tile "DCL_AN3" ON) (mode_tile "DCL_SF3" ON) (mode_tile "DCL_LM3" ON) (TNJ-DCL-UP)) (defun TNJ-DCL-UP (/ TEXT1 TEXT2) (TNJ-GETDATA) (if (= *TNJ-LM1 "1") (setq TEXT1 (SL-NUM2CHAR *TNJ-NUM1)) (setq TEXT1 (itoa *TNJ-NUM1))) (setq TEXT1 (strcat *TNJ-PRE1 TEXT1 *TNJ-SUF1)) (if (= *TNJ-ON2 "1") (if (= *TNJ-LM2 "1") (setq TEXT2 (strcat *TNJ-PRE2 (SL-NUM2CHAR *TNJ-NUM2) *TNJ-SUF2)) (setq TEXT2 (strcat *TNJ-PRE2 (itoa *TNJ-NUM2) *TNJ-SUF2)))) (if (= *TNJ-ON2 *TNJ-ON3 "1") (if (= *TNJ-LM3 "1") (setq TEXT2 (strcat TEXT2 *TNJ-PRE3 (SL-NUM2CHAR *TNJ-NUM3) *TNJ-SUF3)) (setq TEXT2 (strcat TEXT2 *TNJ-PRE3 (itoa *TNJ-NUM3) *TNJ-SUF3)))) (setq text1 (strcat "格式预览 第一行: " TEXT1)) (IF (= (type TEXT2) 'STR)(SETQ TEXT1 (STRCAT TEXT1 " 第二行: " TEXT2))) (set_tile "DCL_PREVIEW" TEXT1)) (defun TNJ-DATANUM () (if (/= (type *TNJ-NUM1) 'INT) (setq *TNJ-NUM1 1)) (if (/= (type *TNJ-NUM1+) 'INT) (setq *TNJ-NUM1+ 1)) (if (/= (type *TNJ-NUM2) 'INT) (setq *TNJ-NUM2 1)) (if (/= (type *TNJ-NUM2+) 'INT) (setq *TNJ-NUM2+ 1)) (if (/= (type *TNJ-NUM3) 'INT) (setq *TNJ-NUM3 1)) (if (/= (type *TNJ-NUM3+) 'INT) (setq *TNJ-NUM3+ 1)) (if (/= (type *TNJ-PRE1) 'STR) (setq *TNJ-PRE1 "")) (if (/= (type *TNJ-PRE2) 'STR) (setq *TNJ-PRE2 "")) (if (/= (type *TNJ-PRE3) 'STR) (setq *TNJ-PRE3 "")) (if (/= (type *TNJ-SUF1) 'STR) (setq *TNJ-SUF1 "")) (if (/= (type *TNJ-SUF2) 'STR) (setq *TNJ-SUF2 "")) (if (/= (type *TNJ-SUF3) 'STR) (setq *TNJ-SUF3 "")) (if (/= (type *TNJ-TH) 'REAL) (setq *TNJ-TH 5))) (defun C:TNJ () (setvar "CMDECHO" 0) (prompt "自动文字编号\n") (command ".UNDO" "BE") (setq *TNJ-DCL-ID (load_dialog "TextNumJ.DCL") *MARK-LIST NIL) (TNJ-DATANUM) (TNJ-DIALOG) (princ)) (defun TNJ-DIALOG (/ DCL_ACT) (new_dialog "TNJDCL" *TNJ-DCL-ID) (if (= *TNJ-LM1 "1") (progn (set_tile "DCL_LM1" "1") (set_tile "DCL_SN1" (SL-NUM2CHAR *TNJ-NUM1))) (progn (set_tile "DCL_LM1" "0") (set_tile "DCL_SN1" (itoa *TNJ-NUM1)))) (set_tile "DCL_AN1" (itoa *TNJ-NUM1+)) (if (= *TNJ-ON2 "1") (progn (set_tile "DCL_ON2" "1") (mode_tile "DCL_PF2" 0) (mode_tile "DCL_SN2" 0) (mode_tile "DCL_AN2" 0) (mode_tile "DCL_SF2" 0) (mode_tile "DCL_LM2" 0)(mode_tile "DCL_ON3" 0)) (progn (set_tile "DCL_ON2" "0") (mode_tile "DCL_PF2" 1) (mode_tile "DCL_SN2" 1) (mode_tile "DCL_AN2" 1) (mode_tile "DCL_SF2" 1) (mode_tile "DCL_LM2" 1)(mode_tile "DCL_ON3" 1))) (if (= *TNJ-LM2 "1") (progn (set_tile "DCL_LM2" "1") (set_tile "DCL_SN2" (SL-NUM2CHAR *TNJ-NUM2))) (progn (set_tile "DCL_LM2" "0") (set_tile "DCL_SN2" (itoa *TNJ-NUM2)))) (set_tile "DCL_AN1" (itoa *TNJ-NUM1+)) (if (= *TNJ-ON2 *TNJ-ON3 "1") (progn (set_tile "DCL_ON3" "1")(mode_tile "DCL_PF3" 0) (mode_tile "DCL_SN3" 0) (mode_tile "DCL_AN3" 0) (mode_tile "DCL_SF3" 0) (mode_tile "DCL_LM3" 0)) (progn (set_tile "DCL_ON3" "0")(mode_tile "DCL_PF3" 1) (mode_tile "DCL_SN3" 1) (mode_tile "DCL_AN3" 1) (mode_tile "DCL_SF3" 1) (mode_tile "DCL_LM3" 1))) (if (= *TNJ-LM3 "1") (progn (set_tile "DCL_LM3" "1") (set_tile "DCL_SN3" (SL-NUM2CHAR *TNJ-NUM3))) (progn (set_tile "DCL_LM3" "0") (set_tile "DCL_SN3" (itoa *TNJ-NUM3)))) (set_tile "DCL_AN1" (itoa *TNJ-NUM1+)) (set_tile "DCL_AN2" (itoa *TNJ-NUM2+)) (set_tile "DCL_AN3" (itoa *TNJ-NUM3+)) (set_tile "DCL_PF1" *TNJ-PRE1) (set_tile "DCL_PF2" *TNJ-PRE2)(set_tile "DCL_PF3" *TNJ-PRE3) (set_tile "DCL_SF1" *TNJ-SUF1) (set_tile "DCL_SF2" *TNJ-SUF2) (set_tile "DCL_SF3" *TNJ-SUF3) (set_tile "DCL_TH" (rtos *TNJ-TH 2 2)) (TNJ-DCL-UP) (action_tile "accept" "(TNJ-GETDATA)(done_dialog 1)") (setq DCL_ACT (start_dialog)) (cond ((= DCL_ACT 1) (TNJ-DATANUM) (TNJ-MARK)))) (defun TNJ-GETDATA () (setq *TNJ-PRE1 (get_tile "DCL_PF1") *TNJ-NUM1 (get_tile "DCL_SN1") *TNJ-NUM1+ (atoi (get_tile "DCL_AN1")) *TNJ-SUF1 (get_tile "DCL_SF1") *TNJ-LM1 (get_tile "DCL_LM1") *TNJ-ON2 (get_tile "DCL_ON2") *TNJ-ON3 (get_tile "DCL_ON3") *TNJ-TH (atof (get_tile "DCL_TH"))) (if (= *TNJ-ON2 "1") (setq *TNJ-PRE2 (get_tile "DCL_PF2") *TNJ-NUM2 (get_tile "DCL_SN2") *TNJ-NUM2+ (atoi (get_tile "DCL_AN2")) *TNJ-SUF2 (get_tile "DCL_SF2") *TNJ-LM2 (get_tile "DCL_LM2"))) (if (= *TNJ-ON2 *TNJ-ON3 "1") (setq *TNJ-PRE3 (get_tile "DCL_PF3") *TNJ-NUM3 (get_tile "DCL_SN3") *TNJ-NUM3+ (atoi (get_tile "DCL_AN3")) *TNJ-SUF3 (get_tile "DCL_SF3") *TNJ-LM3 (get_tile "DCL_LM3"))) (if (= (atoi *TNJ-NUM1) 0) (setq *TNJ-NUM1 (SL-CHAR2NUM *TNJ-NUM1)) (setq *TNJ-NUM1 (atoi *TNJ-NUM1))) (if (= *TNJ-ON2 "1") (if (= (atoi *TNJ-NUM2) 0) (setq *TNJ-NUM2 (SL-CHAR2NUM *TNJ-NUM2)) (setq *TNJ-NUM2 (atoi *TNJ-NUM2)))) (if (= *TNJ-ON2 *TNJ-ON3 "1") (if (= (atoi *TNJ-NUM3) 0) (setq *TNJ-NUM3 (SL-CHAR2NUM *TNJ-NUM3)) (setq *TNJ-NUM3 (atoi *TNJ-NUM3))))) (defun TNJ-MARK (/ SPACE PT1 TEXT1 NEWTEXT1 PT2 TEXT2 NEWTEXT2) (if (= "Model" (getvar "CTAB")) (setq SPACE (vla-get-modelspace *ACADDOC*)) (setq SPACE (vla-get-paperspace *ACADDOC*))) (while (setq PT1 (getpoint "指定编号位置: ")) (setq PT2 (trans (polar PT1 (* pi 1.5) (* 1.25 *TNJ-TH)) 1 0)) (setq PT1 (trans PT1 1 0)) (if (= *TNJ-LM1 "1") (setq TEXT1 (SL-NUM2CHAR *TNJ-NUM1)) (setq TEXT1 (itoa *TNJ-NUM1))) (setq TEXT1 (strcat *TNJ-PRE1 TEXT1 *TNJ-SUF1)) (if (= *TNJ-ON2 "1") (if (= *TNJ-LM2 "1") (setq TEXT2 (strcat *TNJ-PRE2 (SL-NUM2CHAR *TNJ-NUM2) *TNJ-SUF2)) (setq TEXT2 (strcat *TNJ-PRE2 (itoa *TNJ-NUM2) *TNJ-SUF2)))) (if (= *TNJ-ON2 *TNJ-ON3 "1") (if (= *TNJ-LM3 "1") (setq TEXT2 (strcat TEXT2 *TNJ-PRE3 (SL-NUM2CHAR *TNJ-NUM3) *TNJ-SUF3)) (setq TEXT2 (strcat TEXT2 *TNJ-PRE3 (itoa *TNJ-NUM3) *TNJ-SUF3)))) (setq NEWTEXT1 (vla-addtext SPACE TEXT1 (vlax-3d-point PT1) 1) *MARK-LIST1 (append *MARK-LIST1 (list NEWTEXT1))) (vla-put-height NEWTEXT1 *TNJ-TH) (if (= *TNJ-ON2 "1") (progn (setq NEWTEXT2 (vla-addtext SPACE TEXT2 (vlax-3d-point PT2) 1) *MARK-LIST2 (append *MARK-LIST2 (list NEWTEXT2))) (vla-put-height NEWTEXT2 *TNJ-TH))) (setq *TNJ-NUM1 (+ *TNJ-NUM1 *TNJ-NUM1+)) (if (= *TNJ-ON2 "1") (setq *TNJ-NUM2 (+ *TNJ-NUM2 *TNJ-NUM2+))) (if (= *TNJ-ON2 *TNJ-ON3 "1") (setq *TNJ-NUM3 (+ *TNJ-NUM3 *TNJ-NUM3+)))) (TNJ-OP)) (defun TNJ-OP (/ KEY END) (initget "c s u q") (setq KEY (getkword "\n输入选项 [继续(C)/设置(S)/取消末项(U)/退出(Q)]<退出>:")) (cond ((= KEY "c") (TNJ-MARK)) ((= KEY "s") (TNJ-DIALOG)) ((= KEY "u") (if (setq END (last *MARK-LIST1)) (progn (vla-delete END) (setq *MARK-LIST1 (vl-remove END *MARK-LIST1) *TNJ-NUM1 (- *TNJ-NUM1 *TNJ-NUM1+)) (if (= *TNJ-ON2 "1") (setq *TNJ-NUM2 (- *TNJ-NUM2 *TNJ-NUM2+))) (if (= *TNJ-ON2 *TNJ-ON3 "1") (setq *TNJ-NUM3 (- *TNJ-NUM3 *TNJ-NUM3+)))) (alert "已经没有我写的了!别让我擦了!!")) (if (and (= *TNJ-ON2 *TNJ-ON3 "1")(setq END (last *MARK-LIST2))) (progn (vla-delete END) (setq *MARK-LIST2 (vl-remove END *MARK-LIST2)))) (TNJ-OP)) (t (unload_dialog *TNJ-DCL-ID) (command ".UNDO" "E")))) (PRINC "双行文字编号---TNJ")(PRINC)
DCL部份
TNJDCL :dialog{label = "双行多数字序号"; :row{ :boxed_column{label="第一行编号"; spacer_1; :edit_box {key="DCL_PF1";label="前缀";action="(TNJ-DCL-UP)";} :edit_box {key="DCL_SN1";label="初值";action="(TNJ-DCL-UP)";} :edit_box {key="DCL_AN1";label="增量";action="(TNJ-DCL-UP)";} :edit_box {key="DCL_SF1";label="后缀";action="(TNJ-DCL-UP)";} :toggle{key="DCL_LM1";label="字母编号";action="(TNJ-DCL-UP)";} } :boxed_column{label="第二行编号"; :toggle{key="DCL_ON2";label="启用";action="(TNJ-DCL-ON2)";} :edit_box {key="DCL_PF2";label="前缀";is_enabled=false;action="(TNJ-DCL-UP)";} :edit_box {key="DCL_SN2";label="初值";is_enabled=false;action="(TNJ-DCL-UP)";} :edit_box {key="DCL_AN2";label="增量";is_enabled=false;action="(TNJ-DCL-UP)";} :edit_box {key="DCL_SF2";label="后缀";is_enabled=false;action="(TNJ-DCL-UP)";} :toggle{key="DCL_LM2";label="字母编号";is_enabled=false;action="(TNJ-DCL-UP)";} } :boxed_column{label="第二行编号 2"; :toggle{key="DCL_ON3";label="启用";is_enabled=false;action="(TNJ-DCL-ON3)";} :edit_box {key="DCL_PF3";label="前缀";is_enabled=false;action="(TNJ-DCL-UP)";} :edit_box {key="DCL_SN3";label="初值";is_enabled=false;action="(TNJ-DCL-UP)";} :edit_box {key="DCL_AN3";label="增量";is_enabled=false;action="(TNJ-DCL-UP)";} :edit_box {key="DCL_SF3";label="后缀";is_enabled=false;action="(TNJ-DCL-UP)";} :toggle{key="DCL_LM3";label="字母编号";is_enabled=false;action="(TNJ-DCL-UP)";} } } :row{:edit_box {key="DCL_TH";label="字高";} :text {key="DCL_PREVIEW";label="格式预览 ";width=48;}} spacer_0;ok_cancel; } |
