查看: 1554|回复: 2
以下代码为什么不能求得交点也不能划直线
发表于 2005-10-13 13:30:00 | 显示全部楼层 |阅读模式
以下代码为什么不能求得交点也不能划直线
Dim InsPoint(0 To 2) As Double
Dim pt1(0 To 2), pt2(0 To 2), pt3(0 To 2) As Double
Dim SPoint, pt As Variant
Dim Hint As String
Hint = vbCrLf & "Please put in Point:"
SPoint = acadApp.ActiveDocument.Utility.GetPoint(, Hint)
InsPoint(0) = SPoint(0) + 10#
InsPoint(1) = SPoint(1)
InsPoint(2) = 0
pt1(0) = SPoint(0)
pt1(1) = SPoint(1) + 10#
pt(2) = 0
pt2(0) = SPoint(0) + 10#
pt2(1) = SPoint(1) + 10#
pt2(2) = 0
Dim La, Lb As AcadLine
Dim st1, St2, ed1, ed2 As Variant
ed1(0) = pt2(0)
ed1(1) = pt2(1)
ed1(2) = 0
St2(0) = InsPoint(0)
St2(1) = InsPoint(1)
St2(2) = 0
ed2(0) = pt1(0)
ed2(1) = pt1(1)
ed2(2) = 0
Dim cir As AcadCircle
cir = acadApp.ActiveDocument.ModelSpace.AddCircle(pt1, 20)
Set La = acadApp.ActiveDocument.ModelSpace.AddLine(SPoint, ed1)
Set Lb = acadApp.ActiveDocument.ModelSpace.AddLine(St2, ed1)
pt = Lb.IntersectWith(La, acExtendBoth)
请高手指点!
发表于 2005-10-13 17:59:00 | 显示全部楼层
错误太多了!
Sub tttt()
Dim acadapp As AcadApplication
Set acadapp = Application
Dim pt1(0 To 2) As Double, pt2(0 To 2) As Double, pt3(0 To 2) As Double
Dim Hint As String
SPoint = acadapp.ActiveDocument.Utility.GetPoint(, Hint)
InsPoint(2) = 0
pt1(0) = SPoint(0)
pt1(2) = 0
pt2(2) = 0
ed1 = pt2
St2 = InsPoint
ed2 = pt1
Set cir = acadapp.ActiveDocument.ModelSpace.AddCircle(pt1, 20)
Set La = acadapp.ActiveDocument.ModelSpace.AddLine(SPoint, ed1)
Set Lb = acadapp.ActiveDocument.ModelSpace.AddLine(St2, ed1)
End Sub
 楼主| 发表于 2005-10-13 19:03:00 | 显示全部楼层
非常感谢你的帮助
GMT+8, 2025-2-22 18:26 , Processed in 0.175457 second(s), 23 queries , Gzip On.
