(defun c:bbz (/ fac) (if (= fact nil) (setq fact 1.0)) (prompt "\nEnter the Scale Factor<") (princ fact) (princ ">:") (setq fac (getreal)) (if (or (= fac nil) (= fac fact)) (progn (setq fact (/ 1.0 fact)) (command "dimoverride" "DIMLFAC" fact pause) (setq fact (/ 1.0 fact)) ) (progn (setq fac (/ 1.0 fac)) (command "dimoverride" "DIMLFAC" fac pause) (setq fact (/ 1.0 fac))) ) (prompt "\n*****The Program's Designer Is Tang.J.Z.*****") (princ) )
note:如放大4倍﹐就输入4.程序将标注的实测尺寸除以4
