查看: 1471|回复: 0
诊治代码错误:总不能痛快地启动CAD的原因
发表于 2005-10-19 09:19:00 | 显示全部楼层 |阅读模式
我在Excel VBA用getobject 或 creatobject 启动CAD(2004),第一次总会出现错误信息,第二次才能正常,为什么?
Dim CAD as object
Private Function OpenCAD() As Boolean
    OpenCAD = True
    On Error Resume Next
    Set CAD = GetObject(, "AutoCAD.Application.16")
    If Err <> 0 Then
        Err.Clear
        Set CAD = CreateObject("AutoCAD.Application.16")    'CAD2004
        If Err <> 0 Then
            Err.Clear
            Set CAD = GetObject(, "AutoCAD.Application.16.1")    'CAD2005
            If Err <> 0 Then
                Err.Clear
                Set CAD = CreateObject("AutoCAD.Application.16.1")
                If Err <> 0 Then
                    Err.Clear
                    MsgBox "无法启动CAD...", , "Mrqq"
                    OpenCAD = False
                    Exit Function
                End If
            End If
        End If
    End If
End Function
另外,如何在未打开CAD时得到其版本号?
谢谢!
GMT+8, 2025-5-5 04:34 , Processed in 0.131320 second(s), 23 queries , Gzip On.
