查看: 1453|回复: 3
系统变量设置问题
发表于 2005-10-19 10:57:00 | 显示全部楼层 |阅读模式
系统变量设置问题:
在VBA中怎么样用程序实现打开捕捉模式,并且设置捕捉X,Y轴的间距,谢谢大家~
具体用OSMODE怎么设置,问题很着急,谢谢大家~~
发表于 2005-10-19 14:00:00 | 显示全部楼层
ThisDrawing.SetVariable "OSMODE", 695
HELP FILE...
Sub Example_SetSnapSpacing()
    ' This example finds the current Snap spacing and changes it.
    ' Find the current active viewport
    Dim viewportObj As AcadViewport
    Set viewportObj = ThisDrawing.ActiveViewport
    ' Turn on Snap spacing and reset the viewport.
    viewportObj.SnapOn = True
    ThisDrawing.ActiveViewport = viewportObj
    ' Find the current Snap spacing
    Dim XSpacing As Double
    Dim YSpacing As Double
    viewportObj.GetSnapSpacing XSpacing, YSpacing
    MsgBox "X =" & XSpacing & ", Y =" & YSpacing, Title:="SetSnapSpacing Example"
    ' Change the Snap spacing
    XSpacing = XSpacing * 0.5
    YSpacing = YSpacing * 0.5
    viewportObj.SetSnapSpacing XSpacing, YSpacing
End Sub
 楼主| 发表于 2005-10-19 14:28:00 | 显示全部楼层
谢谢斑竹~~
还有一个问题请教:控制极轴捕捉的是哪一个系统变量?
发表于 2005-10-21 11:08:00 | 显示全部楼层
GMT+8, 2025-6-9 04:17 , Processed in 0.154524 second(s), 23 queries , Gzip On.
