查看: 2427|回复: 4
求助vb简单问题
发表于 2005-10-21 09:00:00 | 显示全部楼层 |阅读模式
我想在vb中直接控制AutoCAD画图,请问我该如何把vb与cad连接上呢???
发表于 2005-10-21 09:17:00 | 显示全部楼层
Use the Help files....
In 2004
The following code example uses the Clear and Description properties of Err. If your coding environment does not support these properties, you will need to modify the example appropriately:
Sub Ch2_ConnectToAcad()
    Dim acadApp As AcadApplication
    On Error Resume Next
    Set acadApp = GetObject(, "AutoCAD.Application.16")
    If Err Then
        Err.Clear
        Set acadApp = CreateObject("AutoCAD.Application.16")
        If Err Then
            MsgBox Err.Description
            Exit Sub
        End If
    End If
    MsgBox "Now running " + acadApp.Name + _
           " version " + acadApp.Version
End Sub
Next, set the document variable to the Document object in the AutoCAD application. The Document object is returned by the ActiveDocument property of the Application object.
Dim acadDoc as AcadDocument
Set acadDoc = acadApp.ActiveDocument
From this point on, use the acadDoc variable to reference the current AutoCAD drawing.
 楼主| 发表于 2005-10-23 20:35:00 | 显示全部楼层
thank  you
发表于 2005-11-3 12:31:00 | 显示全部楼层
我需要VB打开AutoCAD的详细程序
发表于 2005-11-3 16:51:00 | 显示全部楼层
已经很详细了
GMT+8, 2026-1-16 02:28 , Processed in 0.177935 second(s), 25 queries , Gzip On.
