查看: 2851|回复: 2
VBA批打印程序(打印同一目录下的DWG)
发表于 2005-10-27 17:39:00 | 显示全部楼层 |阅读模式
不知道哪位兄弟给改进下,如果我用了CLOSE,怎么会出错啊!望高手改进下!初学。
Sub wj()
Dim s As String
Dim Path As String, FileName As String
Dim dwgname As String
Dim point1(0 To 1) As Double, point2(0 To 1) As Double
FileName = "*.dwg"
Path = "C:\123"    '修改路径
    s = Dir(Path & "\" & FileName)
  point1(0) = 70 '打印范围
  point1(1) = 70
  point2(0) = 4130
  point2(1) = 2900
     While s <> ""
     dwgname = Path & "\" & s
        ThisDrawing.Application.Documents.Open dwgname
 If Not ThisDrawing.ModelSpace.Layout.StyleSheet = "acad.ctb" Then ThisDrawing.ModelSpace.Layout.StyleSheet = "acad.ctb" ' 修改打印样式表
   ThisDrawing.ModelSpace.Layout.SetWindowToPlot point1, point2
  ThisDrawing.ModelSpace.Layout.GetWindowToPlot point1, point2
    ThisDrawing.ModelSpace.Layout.PlotType = acWindow
 ThisDrawing.ModelSpace.Layout.UseStandardScale = 0.001 '修改比例
  ThisDrawing.ModelSpace.Layout.PlotWithPlotStyles = True
  If Not ThisDrawing.ModelSpace.Layout.ConfigName = "HP LaserJet 5000LE" Then ThisDrawing.ModelSpace.Layout.ConfigName = "HP LaserJet 5000LE" ' 修改打印机
  If Not ThisDrawing.ModelSpace.Layout.CanonicalMediaName = "A3" Then ThisDrawing.ModelSpace.Layout.CanonicalMediaName = "A3" ' 修改图幅
    ThisDrawing.Plot.NumberOfCopies = 1
  ThisDrawing.ModelSpace.Layout.PlotRotation = ac90degrees
      ThisDrawing.ModelSpace.Layout.PaperUnits = acMillimeters
   ThisDrawing.Plot.PlotToDevice
        s = Dir
     Wend
End Sub
发表于 2005-10-30 20:54:00 | 显示全部楼层
如果在DWG文件中包含若干图形,这个程序恐怕就不应用了!
 楼主| 发表于 2005-10-31 10:01:00 | 显示全部楼层
如果有规律,改下就行了吧
自己改了下重上传
GMT+8, 2025-7-6 05:16 , Processed in 0.165642 second(s), 24 queries , Gzip On.
