查看: 1762|回复: 4
[VBA]编辑文字的问题
发表于 2005-10-28 09:43:00 | 显示全部楼层 |阅读模式
Sub addtext(ByVal X As Variant, ByVal Y As Variant, TextHeight As Double, textString As String)
     Dim tsObj1 As AcadTextStyle
  Set tsObj1 = ThisDrawing.TextStyles.Add("tsObj1")
       ThisDrawing.ActiveTextStyle = tsObj1
     Dim typeface1 As String
     Dim bold1 As Boolean
     Dim italic1 As Boolean
     Dim charset1 As Long
     Dim pitchandfamily1 As Long
     Dim textObj As AcadText
       typeface1 = "仿宋_GB2312"
       bold1 = False
       italic1 = False
       charset1 = DEFAULT_CHARSET
       pitchandfamily1 = FIXED_PITCH
      tsObj1.SetFont typeface1, bold1, italic1, charset1, pitchandfamily1
      tsObj1.height = 40
      tsObj1.width = 0.75
        Dim insPnt(0 To 2)
       insPnt(0) = X: insPnt(1) = Y: insPnt(2) = 0
       TextHeight = 100
     Set textObj = ThisDrawing.ModelSpace.addtext(insPnt, TextHeight, textString)
     textObj.StyleName = "tsObj1"
        textObj.Update
End Sub
运行之后在Set textObj = ThisDrawing.ModelSpace.addtext(insPnt, TextHeight, textString) 的insPnt 提示我类型不匹配,我是初学者,请大家帮忙看看。
发表于 2005-10-28 09:48:00 | 显示全部楼层
Dim insPnt(0 To 2) as double
 楼主| 发表于 2005-10-28 09:50:00 | 显示全部楼层
问题不在这,本来是Dim insPnt(0 To 2) as double这样的,运行之后提示还是“类型不匹配”
发表于 2005-10-28 12:33:00 | 显示全部楼层
 这一句:
改成:
 Set textObj = ThisDrawing.ModelSpace.addtext(textString,insPnt, TextHeight)
发表于 2005-10-28 16:09:00 | 显示全部楼层
把:X、Y的数据类型改为双精度
GMT+8, 2025-6-9 08:40 , Processed in 0.163546 second(s), 23 queries , Gzip On.
