查看: 4736|回复: 30
[LISP]好东西共分享,批打印处理
发表于 2005-10-29 17:12:00 | 显示全部楼层 |阅读模式
  1. 本人用LISP写了一个自动写脚本的程序,另加自动打印,和批打印差不多,还能输入时间控制打印时间,我一直在用很方便的,CAD2000、2004都行,若需要请告诉你的邮箱,提供源程序。
  2. (defun C:DYSZ()
  3. (SZ))
  4. (defun C:PDY(/ dfil qq bbb ml sm mb cdate ct)
  5.    (setvar "CMDECHO" 0)
  6. (alert " 请先把程序加入到启动组内\n\n工具→加载应用程序→启动组…")
  7. (sz)
  8. (setq qq (qf_getFolder "选择DWG所在文件夹:"))
  9. (if qq
  10. (progn
  11. (setq bbb(vl-directory-files qq))
  12. (setq bbb(cdr(cdr bbb)))
  13. (setq ml (open "C:\\dy.scr" "w"))
  14. (setq sm(length bbb))
  15.   (princ ";;目录共有文件 " ml)
  16.   (prin1 sm ml)
  17.   (princ "\n" ml)
  18.   (setq i 0)
  19.    (repeat sm
  20.    (setq mb(nth i bbb))
  21.    (setq dwg(strcat "*" "DWG"))
  22.    (setq dxg(strcat "*" "dwg"))
  23.    (if (or (wcmatch mb dwg) (wcmatch mb dxg))
  24.     (progn
  25.     (setq mb1(strcat qq "\" mb))
  26.     (princ "open " ml)
  27.     (princ mb1 ml)
  28.     (princ "\n" ml)  ;;空一格
  29.     (princ "dy" ml)  ;;CAD执行命令,可重复
  30.     (princ "\n" ml)
  31.     (princ "close" ml)
  32.     (princ "\n" ml)
  33.     (princ "n" ml)
  34.     (princ "\n" ml)
  35.     )
  36.    )
  37. (setq i(1+ i))
  38.   )
  39. (close ml)
  40. ;;(startapp "notepad.exe" "C:\\dy.scr")
  41. )
  42. )
  43. (alert "脚本为C:\\dy.scr,请运行。\n工具→运行脚本…")
  44. (setvar "CMDECHO" 1)
  45. )
  46. ;;qf_getFolder 引至明经社区
  47. (defun qf_getFolder (msg / WinShell shFolder path catchit)
  48.   (vl-load-com)
  49.   (setq winshell (vlax-create-object "Shell.Application"))
  50.   (setq shFolder (vlax-invoke-method WinShell 'BrowseForFolder 0 msg 1))
  51.   (setq
  52.     catchit (vl-catch-all-apply
  53.       '(lambda ()
  54. (setq shFolder (vlax-get-property shFolder 'self))
  55. (setq path (vlax-get-property shFolder 'path))
  56.        )
  57.     )
  58.   )
  59.   (if (vl-catch-all-error-p catchit)
  60.     nil
  61.     path
  62.   )
  63. )
  64. ;;
  65. (defun SZ()
  66. (setq dyp(getstring "\n打印机配置名\(如:hp deskjet 1120C.pc3\): "))
  67. (graphscr)
  68. (vl-bb-set 'dypz dyp)
  69. (setq tz(getstring "\n图纸尺寸\(如:过大尺寸:自定义: 5 600 x 600 毫米 \(横向\)\): "))
  70. (vl-bb-set 'tzcc tz)
  71. (setq dyb(getstring "\n打印比例\(如:1:1.5\): "))
  72. (vl-bb-set 'dybl dyb)
  73. (setq dyy(getstring "\n打印样式表名\(如:acad.ctb\): "))
  74. (vl-bb-set 'dyys dyy)
  75. (setq ti(getstring "\n输出每幅图间隔<秒>: "))
  76. (vl-bb-set 'time ti)
  77. )
  78. ;;;
  79. (defun C:dy(/ second1 second2 time)
  80. (command "cmdecho" 0)
  81. (setq dyp(vl-bb-ref 'dypz))
  82. (if (= dyp nil)
  83.   (progn
  84.   (alert "请先执行批打印配置输入命令!")
  85.   (quit)
  86.   ))
  87. (setq tz(vl-bb-ref 'tzcc))
  88. (setq dyb(vl-bb-ref 'dybl))
  89. (setq dyy(vl-bb-ref 'dyys))
  90. (setq ti(atoi (vl-bb-ref 'time)))
  91. (setq second1 (* 86400.0 (- (getvar "DATE") (fix (getvar "DATE")))))
  92. (command "zoom" "e")
  93. (setq second2 (* 86400.0 (- (getvar "DATE") (fix (getvar "DATE")))))
  94. (setq time(- second2 second1))
  95. (while (= x nil)
  96.   (setq second2 (* 86400.0 (- (getvar "DATE") (fix (getvar "DATE")))))
  97.   (setq time(- second2 second1))
  98.   (if (> time ti)  ;;每秒打印一幅
  99.    (progn
  100.    (setq x T)
  101.    (command "-plot" "y" "" dyp tz "m" "P" "N" "E" dyb "C" "y" dyy "y" "n" "N" "N" "Y")
  102.    ))
  103.   )
  104. (command "cmdecho" 1)
  105. )
  106. 若你的机子不能用请直接修改源代码
发表于 2005-10-29 20:08:00 | 显示全部楼层
@163.com.cn?!!!
有这个吗
发表于 2005-10-30 06:41:00 | 显示全部楼层
你好,能给我一个吗zmcy20032003@163.com
发表于 2005-11-3 19:52:00 | 显示全部楼层
这里可以粘贴原程序啊!我曾经粘贴过打印的!
望对比下!
发表于 2005-11-4 13:02:00 | 显示全部楼层
给我发封邮件吧:iceberg7512@163.com
我也做二次开发,我们可以交流一下。
发表于 2005-11-4 14:41:00 | 显示全部楼层
我的QQ:76370642
发表于 2005-11-5 13:23:00 | 显示全部楼层
非常谢谢!我的邮箱是:
chamous@tom.com
不知你的程序能否解决我的图框大小不一,无规则排放的批打印问题.
 楼主| 发表于 2005-11-5 15:19:00 | 显示全部楼层
不知你是不是需要同一比例,而打印样式完全一致的图件,如果你想让打印之前需要对图形作一些改变,恐怕还需另外的程序处理,这要加在打印之前。
发表于 2005-11-5 18:21:00 | 显示全部楼层
能不能把指定文件夹下的所有图形按顺序打印出来?
能的话请提供给我一份,先谢谢了。
xsjun21@sina.com
发表于 2005-11-7 14:10:00 | 显示全部楼层
你好,
     能给我一个吗JSKSCXL01@163.com
GMT+8, 2025-5-29 03:14 , Processed in 0.195854 second(s), 26 queries , Gzip On.
