查看: 3063|回复: 3
请教如何取得图层列表及相应的颜色与线型列表
发表于 2005-11-1 13:02:00 | 显示全部楼层 |阅读模式
这是BDY老大的取得图层列表的LISP
(defun Get-Laylist-BDY (/ DOC LAY-L LAYS)
  (setq doc (vla-get-activedocument (vlax-get-Acad-Object)))
  (setq lays (vla-get-layers doc))
  (vlax-for item lays
    (SETQ LAY-L (APPEND LAY-L (LIST (vla-get-Name item))))
发表于 2005-11-1 13:22:00 | 显示全部楼层
取得图层名后,使用(cdr (assoc 62 (tblsearch "layer" layname)))获得颜色,,同样,组码6是线形
发表于 2005-11-2 11:40:00 | 显示全部楼层
  1. (defun c:test (/ s1 la co lt lst)
  2.   (setq s1 (tblnext "layer" T)
  3. la  (tbl 2 s1)
  4. co  (tbl 62 s1)
  5. lt  (tbl 6 s1)
  6. lst (cons (list la co lt) lst)
  7.   )
  8.   (while (setq s1 (tblnext "layer" nil))
  9.     (setq la  (tbl 2 s1)
  10.    co  (tbl 62 s1)
  11.    lt  (tbl 6 s1)
  12.    lst (cons (list la co lt) lst)
  13.     )
  14.   )
  15.   (princ"\n层 颜色 线型列表 : ")
  16.   (princ"\n")
  17.   lst
  18. )
  19. (defun tbl (mode ent)
  20.   (cdr (assoc mode ent))
  21. )
发表于 2023-7-8 00:55:56 | 显示全部楼层
感谢大佬分享
GMT+8, 2025-5-14 12:58 , Processed in 0.174268 second(s), 26 queries , Gzip On.
