查看: 2594|回复: 1
[求助]由面域拉伸生成实体的疑问?
发表于 2005-11-3 16:54:00 | 显示全部楼层 |阅读模式
想用以下代码拉伸生成实体,结果什么也没有得到,也没有报错?请大家看看!
'构造选择集
    Dim gear As AcadSelectionSet
    On Error Resume Next
    If Not IsNull(AcadApp.ActiveDocument.SelectionSets.Item("gear_set")) Then
        Set gear = AcadApp.ActiveDocument.SelectionSets.Add("gear_set")
    End If
    gear.Select acSelectionSetAll
    '复制选择集里的对象
    Dim ents(11) As AcadEntity
    For i = 0 To gear.Count - 1
        Set ents(i) = gear.Item(i).Copy
    Next i
    '定义面域
    Dim reg As Variant
    Set reg = AcadApp.ActiveDocument.ModelSpace.AddRegion(ents)
    '拉伸实体
    Dim height As Double
    Dim taperAngle As Double
    height = 8
    taperAngle = 0
    Dim rack As Acad3DSolid
    Set rack = AcadApp.ActiveDocument.ModelSpace.AddExtrudedSolid(reg, height, taperAngle)
 楼主| 发表于 2005-11-3 17:00:00 | 显示全部楼层
是不是定义面域部分就出错了?
面域的属性和方法都不能通过reg对象引用啊?
是怎么回事?
另外,我看到帮助文件里类似的例子在使用AddExtrudedSolid方法是第一个参数写成了数组形式,即写成:
Set rack = AcadApp.ActiveDocument.ModelSpace.AddExtrudedSolid(reg(0), height, taperAngle)
帮助中的实体可以拉伸生成,我的却不行,为什么?
帮助中的例子如下:
Sub Example_AddExtrudedSolid()
    ' This example extrudes a solid from a region.
    ' The region is created from an arc and a line.
    Dim curves(0 To 1) As AcadEntity
    ' Define the arc
    Dim centerPoint(0 To 2) As Double
    Dim radius As Double
    Dim startAngle As Double
    Dim endAngle As Double
    centerPoint(0) = 5#: centerPoint(1) = 3#: centerPoint(2) = 0#
    radius = 2#
    startAngle = 0
    endAngle = 3.141592
    Set curves(0) = ThisDrawing.ModelSpace.AddArc(centerPoint, radius, startAngle, endAngle)
    ' Define the line
    Set curves(1) = ThisDrawing.ModelSpace.AddLine(curves(0).startPoint, curves(0).endPoint)
    ' Create the region
    Dim regionObj As Variant
    regionObj = ThisDrawing.ModelSpace.AddRegion(curves)
    ' Define the extrusion
    height = 3
    taperAngle = 0
    ' Create the solid
    Dim solidObj As Acad3DSolid
    Set solidObj = ThisDrawing.ModelSpace.AddExtrudedSolid(regionObj(0), height, taperAngle)
End Sub
GMT+8, 2026-1-16 02:28 , Processed in 0.158987 second(s), 24 queries , Gzip On.
