查看: 3698|回复: 7
使用UltraEdit-32编辑lisp程序的高亮显示文件
发表于 2005-11-5 01:16:00 | 显示全部楼层 |阅读模式
/L10"AutoLisp" Line Comment = ;; Block Comment On = ;| Block Comment Off = |; String Chars = " File Extensions = lsp
/Delimiters = ~!@%^&*()-+=|\/{}[]:;"'<> , .?
/Indent Strings = "("
/Unindent Strings = ")"
/C1"lisp"
abs acad_colordlg acad_helpdlg acad_strlsort action_tile add_list alert alloc
and angle angtof angtos append apply arx arxload arxunload ascii assoc atan atof
atoi atom atoms-family autoarxload autoload
boole boundp
caddr cadr car cdr chr client_data_tile close command cond cons cos cvunit
defun defun-q defun-q-list-ref defun-q-list-set dictadd
dictnext dictremove dictrename dictsearch dimx_tile dimy_tile distance distof done_dialog
end_image end_list entdel entget entlast entmake entmakex
entmod entnext entsel entupd eq equal eval exit exp expand expt
fill_image findfile fix float foreach function
gc gcd get_attr get_tile getangle getcfg getcname getcorner getdist getenv getfiled getint getkword
getorient getpoint getreal getstring getvar graphscr grclear grdraw grread grtext grvecs
handent help
if initdia initget inters itoa
lambda last layoutlist length list listp load load_dialog log logand logior lsh
mapcar max mem member menucmd menugroup min minusp mode_tile
namedobjdict nentsel nentselp new_dialog not nth null numberp
open or osnap
polar prin1 princ print progn prompt
quit quote
read read-char read-line redraw regapp rem repeat reverse rtos
set set_tile setcfg setenv setfunhelp setq setvar setview sin slide_image snvalid sqrt
ssadd ssdel ssget ssgetfirst sslength ssmemb ssname ssnamex sssetfirst startapp
start_dialog start_image start_list strcase strcat strlen subst substr
tablet tblnext tblobjname tblsearch term_dialog terpri textbox textpage textscr
trace trans type
unload_dialog untrace
vector_image ver vports
wcmatch while write-char write-line
xdroom xdsize
zerop
/C2"Keywords"
T
Nil
/C4"Operators"
 楼主| 发表于 2005-11-5 01:18:00 | 显示全部楼层
是在原文件wordfile的添加的,有些代码不理解,比如如何使1+ 这样的连字符高亮显示?
发表于 2005-11-5 06:55:00 | 显示全部楼层
/C5"lisp函数"
1+
list
listp
atom
map
可用atomfamily 提取到一个文件,粘贴进来就可用
 楼主| 发表于 2005-11-7 09:11:00 | 显示全部楼层
谢谢,您有DCL的编辑支持文件吗?
发表于 2005-11-8 20:53:00 | 显示全部楼层
对对,一直找不到支持DCL的
发表于 2005-11-8 21:18:00 | 显示全部楼层
DCL的编辑支持文件
是指什么?
发表于 2005-11-14 21:23:00 | 显示全部楼层
语法亮显和段落排布(换行、缩进等)
发表于 2013-10-18 12:01:06 | 显示全部楼层
颜色搭配不是很好,黄色的很难看清楚
GMT+8, 2025-7-19 03:56 , Processed in 0.180328 second(s), 27 queries , Gzip On.
