Standard flag values (bit-coded values): 16 = If set, table entry is externally dependent on an xref 32 = If both this bit and bit 16 are set, the externally dependent xref has been successfully resolved 64 = If set, the table entry was referenced by at least one entity in the drawing the last time the drawing was edited. (This flag is for the benefit of AutoCAD® commands. It can be ignored by most programs that read DXF™ files and need not be set by programs that write DXF files)
