查看: 1559|回复: 2
我要选择厚度不会0的对像,请问选择过滤器如何设置
发表于 2005-11-9 19:57:00 | 显示全部楼层 |阅读模式
      过滤器,难道只能用=
      不能用不着<>  ?
发表于 2005-11-9 20:17:00 | 显示全部楼层
reply
可以:
Sub Example_Select()
    ' Create the selection set
    Dim ssetObj As AcadSelectionSet
    Set ssetObj = ThisDrawing.SelectionSets.Add("SSET1")
    ' Add all the Circles to the selection set that lie within the crossing of (28,17,0) and
    ' (-3.3, -3.6,0) by filtering from the current drawing
    Dim gpCode(0 To 1) As Integer
    Dim dataValue(0 To 1) As Variant
    gpCode(0) = -4
    dataValue(0) = "<>"
    gpCode(1) = 39
    dataValue(1) = 0#
    Dim groupCode As Variant, dataCode As Variant
    groupCode = gpCode
    dataCode = dataValue
    ssetObj.Select acSelectionSetAll, , , groupCode, dataCode
    MsgBox ssetObj.Count
    ssetObj.Delete
End Sub
 楼主| 发表于 2005-11-10 20:00:00 | 显示全部楼层
3ku  very much
GMT+8, 2025-5-4 23:22 , Processed in 0.224080 second(s), 23 queries , Gzip On.
