zh:dialog{ label=" 焊 接 符 号"; spacer_1; :row{ :image_button{ key="hjp"; color=0; width=12; aspect_ratio=1.0; } } :boxed_column{ :row{ :toggle{ label="基本符号"; key="tog1"; } :toggle{ label="辅助符号"; key="tog2"; } :toggle{ label="补充符号"; key="tog3"; } :toggle{ label="虚线"; key="tog5"; } } :edit_box{ key="editbox1"; label="焊接数据A: "; } :edit_box{ key="editbox2"; label="焊接数据B: "; } } :boxed_column{ :row{ :toggle{ label="基本符号"; key="togb1"; } :toggle{ label="辅助符号"; key="togb2"; } :toggle{ label="补充符号"; key="togb3"; } :toggle{ label="虚线"; key="togb5"; } } :edit_box{ key="editbox3"; label="焊接数据C: "; } :edit_box{ key="editbox4"; label="焊接数据D: "; } }
:boxed_column{ :edit_box{ label="尾部焊接说明N:"; key="editbox5"; } } spacer_1; ok_cancel; }
