查看: 1591|回复: 2
求助一个关于SelectOnScreen 的问题
发表于 2005-12-2 11:48:00 | 显示全部楼层 |阅读模式
如何用SelectOnScreen方法来只选择块(块参照)
就是sstext.SelectOnScreen FilterType, FilterData
中的条件FilterType,FilterData 应该如何写
谢谢!
发表于 2005-12-2 13:20:00 | 显示全部楼层
Sub Example_SelectOnScreen()
    ' This example adds objects to a selection set by prompting the user
    ' to select ones to add.
    ' Create the selection set
    Dim ssetObj As AcadSelectionSet
    Set ssetObj = ThisDrawing.SelectionSets.Add("TEST_SSET")
    Dim gpCode(0) As Integer
    Dim dataValue(0) As Variant
    gpCode(0) = 0
    dataValue(0) = "Insert"
    Dim groupCode As Variant, dataCode As Variant
    groupCode = gpCode
    dataCode = dataValue
    ' Add objects to a selection set by prompting user to select on the screen
    ssetObj.SelectOnScreen groupCode, dataCode
End Sub
 楼主| 发表于 2005-12-2 14:45:00 | 显示全部楼层
非常感谢版主alin的回答,我找了好久都了
GMT+8, 2025-5-5 00:14 , Processed in 0.183712 second(s), 24 queries , Gzip On.
