查看: 1464|回复: 1
这个面域怎么不能创建
发表于 2005-12-4 14:34:00 | 显示全部楼层 |阅读模式
   Dim curves1(0 To 3) As AcadEntity
 Set curves1(0) = AcadApp.ActiveDocument.ModelSpace.AddArc(basePoint2, h / 2, -pi / 2, pi / 2)
    curves1(0).Rotate3D curves1(0).StartPoint, curves1(0).EndPoint, pi / 2
    Set curves1(1) = AcadApp.ActiveDocument.ModelSpace.AddArc(basePoint3, h / 2, pi / 2, (pi * 3) / 2)
    curves1(1).Rotate3D curves1(1).StartPoint, curves1(1).EndPoint, -pi / 2
    Set curves1(2) = AcadApp.ActiveDocument.ModelSpace.AddLine(curves1(0).EndPoint, curves1(1).StartPoint)
    Set curves1(3) = AcadApp.ActiveDocument.ModelSpace.AddLine(curves1(1).EndPoint, curves1(0).StartPoint)
    ' Create the region
    Dim regionObj As Variant
    Dim regionObj1 As Variant
    regionObj1 = AcadApp.ActiveDocument.ModelSpace.AddRegion(curves1)
 楼主| 发表于 2005-12-4 14:38:00 | 显示全部楼层
出现的错误信息为,输入无效
GMT+8, 2025-5-4 21:58 , Processed in 0.158678 second(s), 23 queries , Gzip On.
