查看: 2281|回复: 1
[求助]excel控制IE
发表于 2003-1-23 01:23:00 | 显示全部楼层 |阅读模式
我想从excel 向IE 发送键击。控制IE ,具体讲是在IE的地址栏里输入“www.yahoo.com”,写了两个工程.都实现不了,请大家帮忙看看,谢谢。
代码1如下:
Sub xx()
Dim RetVal
RetVal = Shell("C:\Program Files\Internet Explorer\Iexplore.exe", 1)
SendKeys "{TAB}", True
SendKeys "www.yahoo.com", True
SendKeys "{ENTER}", True
End Sub
代码2如下:
Sub aaa()
Dim ie As Excel.Application
Set ie = CreateObject("Excel.Application")
ActiveWorkbook.FollowHyperlink Address:="file:///D:/软件库-D/tt.htm", _
NewWindow:=False, AddHistory:=True
Application.WindowState = xlNormal
ie.Visible = True
Application.Visible = True
End Sub
发表于 2003-1-23 09:06:00 | 显示全部楼层
试试引用Microsoft Internet Controls控件
GMT+8, 2025-9-17 04:19 , Processed in 0.172989 second(s), 24 queries , Gzip On.
