查看: 3017|回复: 3
[VBA] 怎么样已有的选择集中移除掉一些内容
发表于 2005-12-14 10:25:00 | 显示全部楼层 |阅读模式
请问:
现有的选择集中有一些实体内容,我想用一个for each ……next 从中判断把不符合条件的内容从选择集中移除掉,应该怎么操作?
发表于 2005-12-14 14:52:00 | 显示全部楼层
9     For k = 0 To SelectionSet.Count - 1
              If (你的条件) Then
                    ReDim deleteObj(0) As Object
                    Set deleteObj(0) = SelectionSet.Item(k)
                    SelectionSet.RemoveItems deleteObj
                    GoTo 9
              End If
         Next
呵呵!大体是这样的...你看看吧^_^
 楼主| 发表于 2005-12-14 15:33:00 | 显示全部楼层
谢谢啦!
发表于 2013-3-11 17:05:40 | 显示全部楼层
Sub RemoveSsetsObjects()
' ´ÓÑ¡Ôñ¼¯ÖÐÒÆ³ý¶ÔÏó
On Error Resume Next
   Dim sset As AcadSelectionSet
   Set sset = ThisDrawing.SelectionSets.Add("SS4")
   sset.SelectOnScreen
   MsgBox sset.Count
   Dim Ent As AcadObject
   Dim deleteObj() As Object
   k = 0
   For Each Ent In sset
       If Ent.Layer = "0" Then
          ReDim Preserve deleteObj(k) 'As Object
          Set deleteObj(k) = Ent
          k = k + 1
       End If
   Next
   sset.RemoveItems deleteObj
   MsgBox sset.Count
   sset.Delete
End Sub
GMT+8, 2025-5-25 00:11 , Processed in 0.165820 second(s), 23 queries , Gzip On.
